Thread: Interior Lighting - lights stay dark when rendered
    Member silversurfer790's Avatar
    2009-01
    6
    Angry Interior Lighting - lights stay dark when rendered
    I know there's been a ton of threads about this and I read probably all of them and still don't get it right.
    I'm using Revit 2013 - and the recessed can lights that come with revit. When rendered they always stay dark.
    1. I changed the wattage 100...but it didn't do the job.
    2. Self-Illumination is clicked on - also doesn't do it
    3. I even painted the inside of the can - nope
    4. There is no glass inside the recessed can...
    What am I doing wrong???I'm at my wits end...I'm sure it's something minor...any help as always highly appreciated.
    I attached a few screen shots of my results...and an example of what I'm trying to achieve...
    2011-06
    70
    Default Re: Interior Lighting - lights stay dark when rendered
    I seem to recall a similar issue about a year ago. I solved it by actually going into the light can family and adding a glass lense to it that would illuminate.
    2009-01
    6
    Ok, I will try that...so basically adding an extruded volume inside the can light family and assigning it a material like glass - ..like glass, white high luminance..
    Thanks for the feedback..I post a pic if it works later.
  1. Problem with lights when rendered
    By bigwhitelotus in forum 3ds Max - General
    Last Post: 2010-08-11, 10:26 AM
  2. Revit 2009 : Interior shaded views are way dark
    By iru69 in forum Revit Architecture - General
    Last Post: 2010-02-05, 02:36 PM
  3. Rendered Lighting On, but doesn't show up...
    By slimchaz in forum Revit Architecture - General
    Last Post: 2008-07-25, 07:50 PM
  4. My first Revit interior (rendered with Vray)
    By jcdecastro in forum Revit - Gallery
    Last Post: 2006-08-04, 04:05 PM
  5. Daylighting and Indirect Lighting in Rendered View
    By artitech in forum Revit - Rendering
    Last Post: 2005-10-25, 12:22 PM
