Thread: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    2004-06
    Memphis TN area
    7,048
    Default Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    A user was just working in a local file of a workshared project when the "Central File is being accessed by someone else and is not available" message, with the key, popped up while he was trying to SWC. No one else is in the file.
    I tried saving the file as a new Central file. It did save and create the file, but then the same message came up again. I hit Cancel and it said File Not Saved. When I closed, it asked me if I wanted to save changes, which I clicked No. Then I tried to open that new file, and the Create New Local box was grayed out. I tried detaching the file, creating ANOTHER new file, and the same things as above happened again. Have tried the same things from 2 different workstations, both giving the same results.
    Any idea what could be going on or what I need to do?
    2004-06
    Memphis TN area
    7,048
    Default Re: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    Looks like there are 2 files inside the backup folder for the Central file in question that are "stuck". I can't delete them even with the Central file itself gone. If I make a new Central File with the same name, I get the same errors again.
    Not sure how it got like that but somehow I'm going to have to figure out how to force delete them off of the server.
    2015-10
    Irvine, CA
    113
    We have had some deleting issues with Revit in the past that were solved on our Win 7 workstations by going into the folder and search options of the windows explorer and i the view tab making sure that the "Always show icons, never thumbnails" is checked. It has something to do with Revit accessing the file while it shows the little thumbnail, even if Revit was closed and the folder wasn't displaying the thumbnail. Totally random shot in the dark, but it might help. It took us a long time to figure this one out with trial and error. We haven't really experienced it since Revit 2012, but who knows...
    2009-11
    380
    Quote Originally Posted by patricks View Post
    .... somehow I'm going to have to figure out how to force delete them off of the server.
    Start the server in safe mode and delete.
  1. Detached Revit Local File - (Anyway to reattach or copy worksets over to central file)
    By Reviting in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2014-05-23, 05:17 PM
  2. 2014: Auto Synchronization to central file upon opening a local Revit file
    By manoshj1534948 in forum Revit - API
    Last Post: 2014-02-05, 04:33 AM
  3. Local File Incompatible with Central File - Revit 2010 Error??
    By ekneer in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-02-18, 03:51 PM
  4. Central File and Local Files save
    By Binu Mathew in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-01-16, 09:30 PM
  5. How do I save Local Client file to become Central file?
    By Richard McCarthy in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-03-29, 06:44 AM
