Thread: Mining (extracting) information from conceptual massing family
    2010-07
    New Orleans
    39
    Question Mining (extracting) information from conceptual massing family
    A divided surface in conceptual massing environment will show its area in its instance properties. Is there a way to get access to that information in the project enviornment once you load the mass family in a project?
    It will be great if this information can be scheduled in a project. Conceptual Mass Area.png
    2009-03
    Somerville, MA
    1,060
    Default Re: Mining (extracting) information from conceptual massing family
    I've linked to this add-in a number of times, but here goes again:
    http://www.apps.case-inc.com/content...eter-parameter
    You should be able to create a shared parameter called "Surface Area" in your family, then using the add-in, migrate the Divided Surface Area value to your shared "Surface Area" value.
    2010-07
    New Orleans
    39
    damon.sidel,
    Thank you very much for your response. I can see this app being very helpful in a lot of sitiuations. So thank you very much for reminding me about it.
    However, in this specific situation, it is not very useful. Maybe I am missing something, and maybe you can point me in the right directions - but the 'Divided Surface Area' parameter that needs to be migrated is not available in the dropdown list of available paramters. What am I doing wrong? / any other work around of this issue?
    2009-03
    Somerville, MA
    1,060
    I haven't tested it with conceptual masses, so you may be correct. You could try doing a roof/floor/wall by face in your project and see if the plugin recognizes the area parameter of the roof/floor/wall.
  1. Conceptual Massing Question
    By kathey1 in forum Revit Structure - General
    Last Post: 2011-09-06, 12:22 PM
  2. Conceptual Massing (Surfaces)
    By ricardo.camelo in forum Revit Architecture - General
    Last Post: 2010-08-27, 01:24 AM
  3. Conceptual Massing: Offset
    By jpyeatt in forum Revit Architecture - General
    Last Post: 2009-12-15, 06:57 PM
  4. 2010 Conceptual Massing Tools
    By Dimitri Harvalias in forum Revit Architecture - General
    Last Post: 2009-05-26, 06:23 PM
  5. Extracting Information from a Family
    By steve.70285 in forum Revit Architecture - Families
    Last Post: 2005-01-13, 08:31 PM
