Thread: Drawing Cleanup Lisp
    2011-11
    Default Drawing Cleanup Lisp
    Hi All CAD Experts, I am a newbie here and need your help.
    I have been working on a project with over 700 sheets, and we start finding out our file sizes are increasing rapidly due to bad AEC blocks from consultants or ADT objects. The AEC parasite is running deep and we are in desperate need to clean our entire project folder.
    So far I found out the only way to truly clean the files is to purge audit and resave into dxf, which should purge all AEC objects. And I figured out it may take 2 passes, one to open the files and saveas dxf, then open newly saved dxf and save it back into dwg. Is that a way to do that in one go, i.e. in the lisp to use a filename variable to open the newly-saved ACAD-filename.dxf ? Any help will be much appreciated !
    Here is what I plan to do:
    Step 1: Open filename.dwg, Purge all, DXFOUT
    Step 2: Open ACAD-filename.dxf, Purge all, Audit, reload Linetype, Scalelistedit, Saveas ACAD-filename.dwg
    2005-06
    in the upper right corner
    3,031
    Default Re: Drawing Cleanup Lisp
    Quote Originally Posted by joeskarfe622324 View Post
    Congratulations on your first post.
    What you want to do is very possible I think.
    It would take me quite a while to work it out though. Similar to This Thread.
    I'm what you would call a beginner-to-intermediate lisper, just enough to be dangerous .
    Another thing to consider, along with this is Terry Cad's Script Creator Program which can be run on all drawings in a folder.
    Maybe another AUGI programmer has better insight and options.
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2017 - REVIT 2017 - Inventor Professional 2015 (when I can)
    2015-10
    Colorado Springs, CO
    369
    1 members found this post helpful.
    The AectoACAD command does what you want also - even appends the file name with acad at the beginning, but skips the dxf process so that more items are able to live on with their current format. It simply kills off all of the aec objects. Our company standard for cleaning up files received from an architect/client is to run this first, as it helps keep our files tidy. I would think a script written around that command would be the simplest way to get from point A to point B.
    "I think I fish, in part, because it's an anti-social, bohemian business that, when gone about properly, puts you forever outside the mainstream culture without actually landing you in an institution." - John Gierach
    2005-06
    3,031
    Quote Originally Posted by Coloradomrg View Post
    Sounds perfect!
    If you use the "Script Creator" program by Terry Cad that I mentioned in my earlier post, you could run it on every drawing in a folder at once, no need for lisp.
    *edit.. maybe you could add a nice PURGE routine to clean up regapps etc, could be loaded and run within the script too.
    Or simply put it in your script as commands.
    Ted
  1. LISP to Help with Drawing Iso's
    By dean.dufrene in forum AutoLISP
    Last Post: 2013-05-03, 06:32 PM
  2. Cleanup your drawing tool: CLEAN UP XREF V1.1
    By MarcooPoloo1981 in forum VBA/COM Interop
    Last Post: 2012-04-15, 05:09 PM
  3. Drawing Cleanup in 2007
    By rwilson.143543 in forum CAD Management - General
    Last Post: 2007-07-20, 08:58 PM
  4. Replies: 0
    Last Post: 2007-05-07, 09:53 PM
  5. autocad map drawing cleanup
    By dlperrings in forum AutoCAD Map 3D - General
    Last Post: 2007-01-26, 04:04 PM
Tags for this Thread
