hello Geeks
i have found one useful lisp file for area (pick poly line and place a text on the dwg)
here is a lisp file
(defun drtxt (/ rn tx ls vl lt ht lb hb nr pt)
(setq tx (strcat "Area: "
(rtos (/ (getvar "area") 1000000) 2 2)
" m2"
rn (getstring "\nRoom Name: ")
(setq ls (list (cons 1 tx))
vl (textbox ls)
vl (cadr vl)
lt (car vl)
ht (cadr vl)
vl (grread T)
nr (car vl)
pt (cadr vl)
(princ "\nInsert Point: ")
(while (/= nr 3)
(command "redraw")
(grdraw pt (setq pt (polar pt 0 lt)) 7)
(grdraw pt (setq pt (polar pt (* pi 0.5) ht)) 7)
(grdraw pt (setq pt (polar pt pi lt)) 7)
(grdraw pt (polar pt (* pi 1.5) ht) 7)
(setq vl (grread T)
nr (car vl)
pt (cadr vl)
) ;end while function
(command "-mtext" pt "w" 0 rn tx "")
(redraw)
) ; end drtxt function
(defun c:pla ()
(setvar "cmdecho" 0)
(while (setq et
(car
(entsel "\nSelect polyline: ")
) ;end car function
) ;end setq function
(command "area" "o" et)
(drtxt)
) ; wnd while funtion
(setvar "cmdecho" 1)
(princ)
) ; end c:pla function
what i want to modify is, just a area without typing a Room Name.
can someone help me edit the original lisp?
i would be very much appreciated, if someone could help me with this.
thanks a lot
YWN
