Thread: Point Label Style - Dragged State - Point to Node
    2012-06
    20
    Default Point Label Style - Dragged State - Point to Node
    Hello,
    We're making plans using X marks for points, but I have noticed that the dragged state label leaders automatically point to the limits of the node (for instance, an X with a scale set to 2.50mm will make the end of the arrow point radially 2.5mm from the node).
    Is there a way of changing this setting to make it point to the node itself rather than the symbol scale? We're using hand drafted leaders in the meanwhile.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,665
    Default Re: Point Label Style - Dragged State - Point to Node
    Quote Originally Posted by sebastien795355 View Post
    Hello,
    It's done that way so the leader isn't obscured by whatever symbol is used for the point. Looks great to me!
    2006-09
    14
    Yes, you can change this behavior. For any given point style, go to the 'Summary' tab, expand 'Marker,' and change the setting for 'Leader stops at marker' to 'No.'
    Hope this helps.
  1. Point label style - Station format
    Last Post: 2014-12-11, 04:18 PM
  2. 2014: Default Point Label Style
    By tim_newsome in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2014-02-19, 04:51 PM
  3. Modifying the label style/ dragged state/ Leader/ line weight
    By eraska in forum AutoCAD Civil 3D - General
    Last Post: 2012-05-22, 02:13 PM
  4. Point/Label Style question.
    By todd.80290 in forum AutoCAD Civil 3D - General
    Last Post: 2012-04-10, 03:05 PM
Tags for this Thread
