Results 1 to 8 of 8
Thread: Text 'Find' command enhancements
    Wish List Administration
    2011-08
    4,581
    Default Text 'Find' command enhancements
    Summary: I would like to see the 'Find' command enhanced
    Description: The Find command is a very powerful tool, but could be greatly enhanced with the following additions:
    1. The ability to keep the results and edit in the drawing without having to close CUI (which is standard for excel/word etc);
    2. The ability to search multiple DWG files outside the file that is open, not just xrefs;
    3. Numbering of results.
    Product and Feature: AutoCAD - Text
    Submitted By: Andrew Fisher on 11/08/2013
    5,714
    Default Re: Text 'Find' command enhancements
    1+
    I've been using Lee's Batch Find & Replace Text routine since I was only a padawan learner.
    Cairo - no, not Illinois
    5,069
    add the ability to find text strings within vertical product annotation, and it's a winner
    PS -- fix the borked wildcard S&R!!!! yes, it works 'as designed'. but the design is borked
    in the upper right corner
    3,504
    +1!!!!!
    (amen to that)
    2006-07
    Northeast US
    31
    If I'm searching for particular text, the FIND command should be able to tell me (WITHOUT checking the List Results option):
    - Where it found the text, i.e. Model Space, Layout, Block, etc.
    - Zoom should work while the FIND dialog box is open so I can get a better idea where I am in a large drawing.
    - Repeated FIND attempts should preserve the last used setting, i.e. look in Entire Drawing, Current Space/Layout or Selected Objects.
    FIND was a very helpful with a current project and actually saved me from having to plot multiple paper copies to double-check my take-off and detailing of a number of components.
    0,0,0 The Origin
    8,570
    Quote Originally Posted by ralph.tulis View Post
    I fully support one wish but, to put it better, the FIND dialogue should be dismissable.
    5,714
    Quote Originally Posted by jaberwok View Post
    I fully support one wish but, to put it better, the FIND dialogue should be [modeless instead of modal].
    FTFY
    0,0,0 The Origin
    8,570
    FTFY
    Ta !
  1. Edit within Find Text command
    Last Post: 2016-02-01, 02:47 PM
  2. Edit within Find Text command
    Last Post: 2014-01-28, 02:48 PM
  3. 2013: Using the find command for text in 2013 properly
    By rockrat in forum AutoCAD General
    Last Post: 2013-01-04, 08:55 PM
  4. 2012: Find/Replace command for Dimension Text
    By WYSIWYG-BIM in forum Revit Architecture - General
    Last Post: 2012-05-11, 04:07 PM
  5. Highlight Text From the Find and Replace Command
    Last Post: 2007-05-02, 05:12 PM
