Results 1 to 1 of 1
Thread: Engineering Graphic Scale Block that annotates from Viewport scale
    2006-03
    19
    Default Engineering Graphic Scale Block that annotates from Viewport scale
    I would like to place an Engineering graphic scale block, (scales generally used 1"=10', 20', 30', 40', 50', 100', 200') where the block is annotated by the viewport scale. I don't care for the "out of the box" graphic scales from 'layout' on the 2014 C3D ribbon.
    Thanks in advance for your help.
  1. Annotate Graphic Scale Block by Viewport scale
    By msmith.109036 in forum AutoCAD Customization
    Last Post: 2013-11-12, 05:58 PM
  2. Object / Viewport Scale field in a block?
    By Cavediver in forum AutoCAD Fields
    Last Post: 2012-09-04, 03:22 PM
  3. Dynamic Block - Viewport Scale
    By paul.142634 in forum Dynamic Blocks - Technical
    Last Post: 2009-07-16, 03:47 PM
  4. Replies: 0
    Last Post: 2006-11-28, 10:37 PM
  5. dynamic block to scale by viewport when loaded
    By tim.ashton in forum Dynamic Blocks - Technical
    Last Post: 2006-06-14, 09:45 PM
