Hello,
Like the question says. I build my custom spec with Item Code. Use it in my model and add Item code in table setup at Project properties/ setup title block option. But when I create the Iso I get no warnings and my last column of my BOM is missing. The Item Code is stated in PCF file and in IsoConfig.xml under BOM simpletype section. I am using 2013 plant 3d.
Thanks for the help in advance
