Hi,
We will be upgrading Autodesk suite 2013 to 2014 version. we have a single server network licence in place now. Do I need to upgrade the server licence as well?
Thanks & Regards,
Marudhu Pandian
Hi,
Thanks & Regards,
Marudhu Pandian
Are you on subscription? If so, did you receive a new license last spring (that included the 2014 products) and install that on your license server? If so, you may be good to go. If you got the license for the 2014 products, but did not install it, then you probably need to do that first.
If you are not on subscription (is that even possible with Revit?), and just purchased the 2014 suite, you should have received a new license file for use with the 2014 products, which would have to be added to your license server.
