Thread: Trouble creating form
    2009-03
    Somerville, MA
    1,052
    Default Trouble creating form
    I'm having trouble creating a form as a mass. Initially, I created it in Rhino and imported it into an In-Place mass as an SAT. First attempt was a fail because Revit couldn't do Wall-by-Face on the end parts. So I tried a few other ways of creating the geometry in Rhino. Revit either couldn't create the Wall-by-Face or couldn't even create the geometry.
    So I decided to create the mass as a Revit Conceptual Mass. There I'm having trouble even creating the mass from scratch!
    I've been using splines, but I'd be happy to approximate the edge curves as tangent arcs. Anything that works at this point. As you can see it is essentially a flattened half-cylinder with squished quarter spheres.
    2010-08
    Default Re: Trouble creating form
    how's this?
    2009-03
    Somerville, MA
    1,052
    That may work! I'll take a closer look. How did you create the end?
    2010-08
    Quote Originally Posted by damon.sidel View Post
    sorry it took so long for me to answer back, i kinda forgot i posted here.
    The end is just a 180º revolve around an axis. i created both profile and axis as reference lines, so you can find them again in the file.
  1. AB326-1V: Into the Void: The Zen of Creating Complex Sculptural Form with Autodesk® Revit®
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:58 PM
  2. AB427-3: Into the Void: The Zen of Creating Complex Sculptural Form with Autodesk® Revit®
    Last Post: 2015-08-07, 02:11 PM
  3. What is the key to success in creating a piece of furniture with form?
    By swhetten in forum AutoCAD 3D (2006 or below)
    Last Post: 2006-11-26, 08:58 AM
  4. Creating file form one tab/sheet
    By Donnachiej in forum AutoCAD Customization
    Last Post: 2005-08-29, 03:55 PM
  5. Importing/Creating linework form GIS Data
    By gaston in forum Civil 3D - Civil Design Companion - General
    Last Post: 2004-11-02, 09:42 PM
