Thread: WPF user control instead of a Winform
    2004-06
    Port Moody, BC
    349
    Default WPF user control instead of a Winform
    I would like to test WPF as an improvement to Winforms (I think I have the correct terms)
    So I tried the following:
    I created an Addin
    I inserted a WPF user control as its the only thing available under WPF
    I then added imports System.Windows the xaml.vb and within the class Inherits window
    this allows me to treat the WPF user control as a window so that I can use .ShowDialog() to get it open
    But I get the following error:
    Error 1 Base class 'System.Windows.Controls.UserControl' specified for class 'Home' cannot be different from the base class 'System.Windows.Window' of one of its other partial types.
    the System.Windows.Controls.UserControl is automatically generated in a file named Home.g.vb
    so to my question
    I guess that adding a user control is different to a form, which is what I want..... so is there some documentation out there about adding a WPF form to a revit api?
    Drew
    2004-06
    Port Moody, BC
    349
    Default Re: WPF user control instead of a Winform
    I see I may be able to load the user control into a window with:
    Dim userControl As New UserControl1()
    Dim win As New Window()
    win.Content = userControl
    win.Show()
    so maybe I will give that a try...
    2009-11
    5,719
    Hi Drew,
    Sounds like you're wanting to host a WPF UserControl within a PalettSet, in which case, consider Kean's article here as a loosely related reference.
    HTH
    Computer Specs:
  1. Release a .dll with a WinForm
    By sherlock_62_m549011 in forum Dot Net API
    Last Post: 2014-11-16, 03:36 PM
  2. AB104-3: AutoCAD Architecture: Display Control for the Common User
    By Autodesk University in forum Building Design
    Last Post: 2013-05-05, 03:13 AM
  3. Give the user more control
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2012-03-29, 02:11 PM
  4. User-created phase filter won't control linked file
    By petervanko in forum Revit Architecture - General
    Last Post: 2010-10-25, 05:44 PM
  5. User Customizable Width Property for Toolbar Control Boxes
    Last Post: 2008-06-11, 10:58 AM
