Thread: Delete Key doesn't work on my Mac Book Pro in AutoCAD 2014
    2013-11
    3
    Default Delete Key doesn't work on my Mac Book Pro in AutoCAD 2014
    Help! I installed Windows on my new mac book pro ( w/ bootcamp not parellels) and when I'm in autocad 2014 the delete key doesn't work. It works when I'm in Revit just not AutoCad. Is this a mac UI issue capability with autocad or is this something i can change/fix?
    Also, when i go into some of the menus only half of the text shows. (**SEE Attachment for more clarification)
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,103
    Default Re: Delete Key doesn't work on my Mac Book Pro in AutoCAD 2014
    Is your PICKFIRST system variable set to 0? Typically, the delete key will work when PICKFIRST is set to 1.
    2013-11
    3
    Yes my pickfirst is already set to 1. still doesn't work
    100 Club Brian Benton's Avatar
    2015-06
    at home
    183
    The delete key hardware is different on a MBP for some reason it seems. It seems to be more of a backspace key. I've installed Windows via Bootcamp on my MBP as well as AutoCAD 2014 and I am seeing the same thing.
    2014-04
    e= erase is the only way
    if pickfirst =1 doesnt work,
    if bootcamp> keyboard > tick the box use f1,f2, etc doesnt work....
  1. 2014: Delete Key doesn't work on my Mac Book Pro in AutoCAD 2014
    By LemonTree in forum AutoCAD General
    Last Post: 2013-11-15, 03:04 PM
  2. Replies: 7
    Last Post: 2013-10-25, 08:27 PM
  3. My delete key doesn't work in Autocad
    By mdaigr2 in forum AutoCAD General
    Last Post: 2013-08-21, 12:43 AM
  4. AutoCAD 2008 Informatin Center doesn't work
    By lvsuccess in forum AutoCAD General
    Last Post: 2008-10-05, 02:41 AM
  5. Delete key doesn't work!
    By iainslie in forum AutoCAD General
    Last Post: 2006-11-01, 06:19 PM
Tags for this Thread
