Thread: Autocad 2014 : Layer management problem
    2004-07
    Baton Rouge, Louisiana
    254
    Default Autocad 2014 : Layer management problem
    recently this has started, when I open a drawing that had Xref's attached and I select and xref to change colors, linetype's etc., I get all layers a from other xref's and general layers that we use. I have searched in help and all thru the forums for something similar looking for answers. can not find anything. if anyone had any suggestions it would be appreciated.
    2015-10
    Colorado Springs, CO
    369
    Default Re: Autocad 2014 : Layer management problem
    Do you mean when you select the layer filter for the xref your layers aren't filtered on screen?
    Click the wrench in the upper right corner of the layers pallete. Go down to Dialog Settings, and then make sure the box is check for "apply layer filter to layer toolbar".
    I believe this is a broken part of 2014, as it didn't used to work that way.
    2004-07
    254
    that worked, thanks
  1. Replies: 5
    Last Post: 2014-05-05, 02:33 PM
  2. 2014: Revit Server 2014 - User Management
    By nikipetkov147449 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2014-04-21, 06:36 PM
  3. AutoCAD MEP 2014 - Layer Key Prefixes
    By Elliot Pleitez in forum ACA/AMEP Styles Library
    Last Post: 2013-06-12, 10:09 PM
  4. 2014: AutoCAD 2014 - Problem Viewing Transparencies applied to Hatches.
    By Statboy in forum AutoCAD General
    Last Post: 2013-05-17, 01:54 PM
  5. AutoCAD 2012 LT- Layer problem
    By cheryla in forum AutoCAD LT - General
    Last Post: 2012-01-28, 11:04 PM
