Results 1 to 6 of 6
Thread: Switching Between Viewports in Paper space
    Member WileECoyote's Avatar
    2005-12
    West Bloomfield, MI
    31
    Default Switching Between Viewports in Paper space
    I have a colleague who is having some issues switching between viewports in paper space. When he has two viewports in one paper space he will click on viewport #1 do his work and then double click off to the side to close the viewport. then when he tries to access viewport #2 by clicking on viewport #2 it opens viewport #1 and vice versa...I originally thought it was the SPACESWITCH system variable but that did not seem to do the trick, even though it was set to 0 when i checked it. I changed it to 1 and it is still doing what i have described above. Any thoughts? I am all out of ideas.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Switching Between Viewports in Paper space
    Are the viewports on top of each other? You can cycle between viewports with the CTRL+R shortcut.
    2005-12
    West Bloomfield, MI
    31
    No they are not on top of each other. The CTRL+R will have to work until we get this figured out.
    2002-01
    jUSt Here (a lot)
    9,105
    That is strange.
    2005-12
    West Bloomfield, MI
    31
    That is strange.
    My thoughts exactly.
    2004-05
    Custer, Washington
    126
    How about if instead of double clicking out of the first viewport just click into the second viewport. Does that work.
  1. "Viewport is view-locked. Switching to Paper space."
    By ordengate in forum AMEP General
    Last Post: 2012-05-29, 01:50 PM
  2. 2004: Viewports in paper space
    By gsteffen642486 in forum ACA General
    Last Post: 2012-05-22, 02:49 PM
  3. Viewports in paper space
    By ntormey in forum AutoCAD General
    Last Post: 2012-03-31, 03:15 AM
  4. Replies: 2
    Last Post: 2007-06-17, 03:51 PM
  5. Invisible paper space viewports
    By jrd.chapman in forum AutoLISP
    Last Post: 2004-08-17, 01:29 PM
