Thread: How to use fields between 2 drawings through SSM
    2013-11
    Post How to use fields between 2 drawings through SSM
    Hi, folks!
    I want as many of us automate my rutin work of transfering values among tables of different drawings. How to organize this thransfer?
    I get mass value of support structure from one drawing, then I copy this value to erection drawing to bill of supports table. Maybe is it possible to define custom property of sheet and assign this for next use in other drawing by fileds?
    If this have been resolved, let me know where!
    Cairo - no, not Illinois
    5,069
    Default Re: How to use fields between 2 drawings through SSM
    It's possible to connect a field in one drawing, to a custom sheet property in another sheet via the sheet set manager. When you create the field, under Category select "SheetSet", then scroll down to "SheetSet" in the list. in the middle column, browse to the sheet set you want to connect with , presumably the current sheetset, then select the specific sheet you want to link to. Then, on the far right column, select the sheet property or custom property you want to display.
  1. Linking Fields across drawings
    By finney13 in forum AutoCAD Fields
    Last Post: 2012-06-12, 12:35 AM
  2. Edit Fields Multiple Drawings
    By CindyD in forum AMEP General
    Last Post: 2010-07-09, 02:14 PM
  3. Fields referencing other drawings?
    By cwade in forum AutoCAD Fields
    Last Post: 2006-08-01, 03:39 AM
  4. Use Fields to extract data from other drawings
    Last Post: 2005-10-21, 02:00 PM
  5. new sheet set with existing drawings custom fields
    By jkipfer in forum AutoCAD Sheet Set Manager
    Last Post: 2005-02-22, 04:57 PM
