Hi there.
I want to cut at a CNC machine some parametric boxes from plywood.
I need to have a family with the boxes and some version of it with different sizes (around 35).
So I planned to have a family and make some sections views where I would isolate every piece of plywood and after that when I put all of them in a model I will make probably a script that will export every sections from the families in a dwg for CNC cutting.
My problem is that I can not make an isolation of faces permanently and after I save and open again my isolation are gone and i have to make them again. I was thinking about using Assembly views but it will be a little hard to create for 35 boxes.
Please let me know if you think is some other way i could do this.
Thanks a lot!
