Thread: constructing an arc tangent to an arc and a line
    2015-09
    17
    Default constructing an arc tangent to an arc and a line
    Since I have needed to draw an arc that is tangent to both another arc and a line, I thought I would share what I've learned. The fillet command doesn't usually give me what I need in these instances. See attached PDF.
    tangent arcs.pdf
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Default Re: constructing an arc tangent to an arc and a line
    That's one way to do it. Another way would have you extend the smaller arc beyond the point in which you think the tangent point between the two arcs would be. Then draw a the larger circle using the tangent-tangent-radius option and picking points on the line and a point near the projected tangent point on the arc.
  1. Arc Tangent to Line or Arc with Osnap
    Last Post: 2014-11-13, 12:07 PM
  2. Tangent line to a circle
    By kberger in forum AutoCAD General
    Last Post: 2013-08-07, 12:59 PM
  3. Replies: 0
    Last Post: 2011-11-22, 05:01 AM
  4. Draw a line tangent to two circles
    By pmg456037 in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-02-23, 06:34 PM
  5. Draw Arc tangent to Line
    By Jack Cheong in forum AutoCAD General
    Last Post: 2010-01-22, 08:35 PM
Tags for this Thread
