I want to be able to set the autocad drawing template for QNEW different for each vertical. Is there a system variable I can use to check if AutoCAD is Civil 3D, plain, etc.?
I will be setting QNEW using the following code:
Code:(vla-put-QNewTemplateFile (vla-Get-Files (vla-Get-Preferences (vlax-get-acad-object))) "U:\\AutoCAD\\Templates\\some_file.dwt")
