Results 1 to 6 of 6
Thread: Fast Key or LISP for setting view into a previously created "named view"
    2013-07
    7
    Default Fast Key or LISP for setting view into a previously created "named view"
    Is it a common problem for the view of a drawing in Civil 3D to be thrown out of whack? By this I mean when opening a drawing or after switching from a plot tab to model space the view is no longer from above as if looking down on a sheet but sideways as if looking at it from eye level with the table it sits on.
    I wrote a fast key to correct the view problem and it is this:
    (defun C:gg () (setvar "CMDECHO" 0)(command ".plan" "c")(prin1))
    This fixes the problem by putting it back into a view from current UCS but I was wondering if I could go one step further and throw it into a view that I have already set up for plotting. So essentially, what I would like to happen is I enter the "gg" command and all that would be viewed on the screen is the sheet with borders (our borders are in model space), or the extents of what is plotted on a sheet.
    Does this involve any LISP programming? I have no background knowledge of how to write LISP but I could probably pick up what's necessary to do the job. Please, any help is greatly appreciated!
    Cairo - no, not Illinois
    5,069
    Default Re: Fast Key or LISP for setting view into a previously created "named view"
    (DEFUN c:gv () (command "-view"  "r" "plotting_view")(princ))
    untested
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Naturally, you would need to change the "plotting_view" name in cadtag's code to your typical view name.
    2009-11
    5,719
    Thread moved to LISP forum.
    Computer Specs:
    2013-07
    7
    This looks great! I won't be able to test it until I'm at work tomorrow but I will respond with my success story hopefully. Thank you very much everyone
    2013-07
    7
    Works like a charm! thank you, cadtag
  1. Improve the way "reference other view" view selection works
    By houston.cad in forum Revit Platform - Wish List
    Last Post: 2014-12-19, 06:22 PM
  2. Replies: 0
    Last Post: 2012-06-06, 11:54 AM
  3. "detail view" vs "floor plan" in callouts
    By shane.249457 in forum Revit Architecture - General
    Last Post: 2011-03-08, 09:29 PM
  4. Ability to "flatten" a model view into a drafting view.
    Last Post: 2009-09-06, 06:21 AM
  5. Replies: 3
    Last Post: 2007-10-23, 09:06 PM
