Thread: Attach Space Parameters to Electrical Objects
    Wish List Administration
    2011-08
    4,581
    Default Attach Space Parameters to Electrical Objects
    Summary: Make "Space Parameters" attach to electrical recepticals, electrical equipment (paneboards & switchboards), lighting fixtures, wall switches etc.
    Description: We need to be able to extract a "schedule" of electrical devices indicating what floor the object is installed, what space or room the object is installed in and possible what type of wall a device is hosted to. Using AutoCAD MEP, this is possible but not Revit unless I am missing something here. We need to be able to extract geographic space information from each electrical element the Revit model and then schedule them to be palletized for delivery to the specific room where the devices are to be installed. In the case of wall mounted receptacles, having the wall type attach to the receptacle will determine what type of internal wall support brackets are needed for the "assembly".
    Product and Feature: Revit MEP - Annotation Tools
    Submitted By: Martin Madert on 12/20/2013
    2001-12
    Irvine, CA
    7,567
    Default Re: Attach Space Parameters to Electrical Objects
    The relationship is reversed in Revit. You create a Space schedule and then use an embedded schedule to add a schedule of electrical equipment or one for devices. The formatting of the resulting schedule is still pretty crude. It would be better if Revit was able to generate what some call Room Data Sheets. There are other applications that help tap into Revit to extract and report such info like CodeBook, dRofus and others. You can even use Revit, Word/Excel and Mail Merge. You can read about that At RevitForum.org.
    2011-08
    4,581
    Exclamation Re: Attach Space Parameters to Electrical Objects
    This wish has been reported as granted and already in the software.
    2011-08
    4,581
    The wish has already been granted. This thread is closed to further posts.
  1. Space tags to make use of space parameters in formulae and visibility.
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2015-10-12, 04:56 PM
  2. 2013: Schedules: Space Parameters: People & Electrical Loads
    By octobersky345382 in forum Revit MEP - General
    Last Post: 2013-10-30, 12:23 AM
  3. 2009: Objects in Model Space do not show in Paper Space
    By lupdike407158 in forum AutoCAD General
    Last Post: 2013-08-06, 09:12 PM
  4. Hatch attach to Area Space
    By tra1133 in forum ACA General
    Last Post: 2009-11-24, 04:30 PM
  5. Match Objects from Model Space with Paper Space Objects
    Last Post: 2007-09-18, 01:56 PM
