You're posting in the VBA forum, not the LISP forum...
I've done what you're asking in VBA, but not in VLISP.
Fixo from the theswamp.org supplied the following code, which checks for a valid AutoCAD install.
' require references to:
'Windows Script Host Object model
'AutoCAD 20XX Type Library
'AutoCAD Focus Control for VBA Type Library
'in the Tools -> Options -> General -> Error Trapping box -> Check "Break on Unhandled Errors"
Function acadVerNum() As String
Dim verNum As String
verNum = "HKEY_CLASSES_ROOT\AutoCAD.Drawing\CurVer\"
Dim wsh As Object
On Error GoTo ErrorHandler
'access Windows scripting
Set wsh = CreateObject("WScript.Shell")
'read key from registry
Dim resKey As String
resKey = wsh.RegRead(verNum)
acadVerNum = Right(resKey, 2)
Exit Function
ErrorHandler:
'key was not found
acadVerNum = ""
End Function
Here's some VBA code which runs in Excel and creates a graph in AutoCAD...you _should_ be able to leverage the code to create a solution for your project.
Good luck!
Sub DrawChart(MaxHor As Single, MaxVert As Single, VertLbl As String, HorScale As Single, VertScale As Single, AxisStep)
Dim Txt0LayClr As Integer, Txt1LayClr As Integer, GridColor As Integer
Dim LineTypeObject As AcadLineType
Dim GraphLineHor As AcadLine, GraphLineVer As AcadLine, GridLineHor As AcadLine
Dim GridLineVer As AcadLine, TickLine As AcadLine, ChartLine As AcadLine
Dim TickLabel As AcadText
Dim AxixLabel As AcadText, TempText As AcadText
Dim TextString As String, LineType As String, LayerName As String
Dim TxtLayName As String, BrdrLayName As String, GridLayName As String
Dim Zero As String, TxtHdrLayName As String
Dim ticklength As Double
Dim MaxX As Double, MaxY As Double
Dim Xscale As Double, Yscale As Double
Dim LabelTxtPt(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
Dim GridStart(0 To 2) As Double
Dim GridEnd(0 To 2) As Double
Dim GraphStartPt(0 To 2) As Double
Dim GraphXEndPt(0 To 2) As Double
Dim GraphYEndPt(0 To 2) As Double
Dim TickPtStart(0 To 2) As Double
Dim TickPtEnd(0 To 2) As Double
Dim BigTxt As Double, MedTxt As Double, SmallTxt As Double
Dim acad As AutoCAD.AcadApplication
Dim adoc As AutoCAD.AcadDocument
Dim aspace As AcadBlock
Dim Alayer As AcadLayer
Dim entArray() As AcadEntity
Dim appNum As String
appNum = acadVerNum
If appNum = "" Then
Exit Sub
End If
On Error Resume Next
Set acad = GetObject(, "Autocad.Application." & appNum)
If Err.Number = 429 Then
Err.Clear
On Error GoTo 0
Set acad = CreateObject("Autocad.Application." & appNum)
If Err Then
Exit Sub
End If
End If
acad.WindowState = acMax
Set adoc = acad.ActiveDocument
Set aspace = adoc.ActiveLayout.Block
' Setup Layers for text, grids, and borders
TxtLayName = "Text0"
TxtHdrLayName = "Text1"
Txt0LayClr = 11
Txt1LayClr = 10
BrdrLayName = "P0C"
GridLayName = "GRID"
GridColor = 253
MaxX = MaxHor ' Passed into the routine
MaxY = MaxVert ' Passed into the routine
Call MakeSetLayer(TxtLayName, 11)
Call MakeSetLayer(BrdrLayName, 1)
Call MakeSetLayer(GridLayName, 253)
If adoc.ActiveLayer.Lock Then
adoc.ActiveLayer.Lock = False
End If
'Set LineTypeObject = AcadLineType.Load(LineType, LineTypeFileName)
adoc.Linetypes.Load "DOT", "acad.lin"
' Note: The chart is drawn in Autocad based on 1 = 1
Xscale = HorScale: Yscale = VertScale
' Setup the x-axis and y-axis scaling based on the HorScale variable
'If HorScale >= 1# Then
' Xscale = 1 / HorScale: Yscale = 1#
'Else
' Xscale = 1#: Yscale = HorScale
'End If
' Setup the values for the text height
BigTxt = 12 ' Axis labels
MedTxt = 10 ' Tick labels
SmallTxt = 8 ' Data series labels
' Size the 'tick'
ticklength = 10
' Set the layer for the border and ticks
MakeSetLayer (BrdrLayName)
' Define the border of the chart
GraphStartPt(0) = 0#: GraphStartPt(1) = 0#: GraphStartPt(2) = 0#
GraphXEndPt(0) = MaxX * Xscale: GraphXEndPt(1) = 0#: GraphXEndPt(2) = 0#
GraphYEndPt(0) = 0#: GraphYEndPt(1) = MaxY * Yscale: GraphYEndPt(2) = 0#
' Horizontal Axis Line
Set GraphLineHor = aspace.AddLine(GraphStartPt, GraphXEndPt) ' need to change the color
With GraphLineHor
.LineType = "BYLAYER"
.Color = acByLayer
End With
'Vertical Axis Line
Set GraphLineVer = aspace.AddLine(GraphStartPt, GraphYEndPt)
With GraphLineVer
.Color = acByLayer
End With
' Set the current layer to "Text" for the labels
MakeSetLayer (TxtHdrLayName)
' Label Horizontal Axis
TextPoint(0) = (MaxX * Xscale) / 2
TextPoint(1) = -2.5 * BigTxt
TextPoint(2) = 0#
TextString = "HORIZONTAL SPAN"
Set TempText = aspace.AddText(TextString, TextPoint, BigTxt)
With TempText
.Alignment = acAlignmentTopCenter
.TextAlignmentPoint = TextPoint
End With
' Label Vertical Axis
TextPoint(1) = (MaxY * Yscale) / 2
TextPoint(0) = -5# * BigTxt
TextPoint(2) = 0#
TextString = VertLbl
With TempText
.Rotation = pi() / -2
End With
' Place and label the tick marks and grid lines
Dim i As Integer
' Draw ticks and label for the horizontal axis
For i = 0 To MaxX * Xscale Step (AxisStep / 2)
Select Case (i Mod AxisStep) ' need to have the scale correct
Case 0
TickPtStart(0) = CDbl(i): TickPtStart(1) = 0#: TickPtStart(2) = 0#
TickPtEnd(0) = CDbl(i): TickPtEnd(1) = (-1 * ticklength): TickPtEnd(2) = 0#
Set TickLine = aspace.AddLine(TickPtStart, TickPtEnd)
MakeSetLayer (TxtLayName)
TextString = CStr(i / Xscale)
TickPtEnd(1) = (-1.1 * ticklength)
Set TickLabel = aspace.AddText(TextString, TickPtEnd, MedTxt)
With TickLabel
.TextAlignmentPoint = TickPtEnd
End With
Case Else
TickPtEnd(0) = CDbl(i): TickPtEnd(1) = (-0.5 * ticklength): TickPtEnd(2) = 0#
End Select
Next i
' Draw the vertical grid lines
MakeSetLayer (GridLayName)
For i = 10 To (MaxX * Xscale) Step (10)
GridStart(0) = CDbl(i): GridStart(1) = 0#: GridStart(2) = 0#
GridEnd(0) = CDbl(i): GridEnd(1) = Round(MaxY * Yscale, 0): GridEnd(2) = 0#
Set GridLineVer = aspace.AddLine(GridStart, GridEnd)
Next i
' Draw the ticks for the vertical axis
For i = 0 To MaxY * Yscale Step (AxisStep / 2)
' Only label the 100's
Select Case i Mod (AxisStep)
Case 0
' Label the ticks
TickPtStart(1) = CDbl(i): TickPtStart(0) = 0#: TickPtStart(2) = 0#
TickPtEnd(1) = CDbl(i): TickPtEnd(0) = (-1 * ticklength): TickPtEnd(2) = 0#
LabelTxtPt(1) = CDbl(i): LabelTxtPt(0) = -1.5 * MedTxt: LabelTxtPt(2) = 0#
TextString = CStr(Round(i / Yscale, 0))
Set TickLabel = aspace.AddText(TextString, LabelTxtPt, MedTxt)
With TickLabel
.Rotation = 0
.Alignment = acAlignmentMiddleRight
.TextAlignmentPoint = LabelTxtPt
End With
Case Else
TickPtEnd(1) = CDbl(i): TickPtEnd(0) = (-0.5 * ticklength): TickPtEnd(2) = 0#
End Select
Next i
' Draw the horizontal gridlines
For i = 10 To MaxY * Yscale Step (10)
GridStart(0) = 0#: GridStart(1) = i: GridStart(2) = 0#
GridEnd(0) = MaxX * Xscale: GridEnd(1) = CDbl(i): GridEnd(2) = 0#
Set GridLineHor = aspace.AddLine(GridStart, GridEnd)
Next i
adoc.Activate
ZoomExtents
' Lock the grid layer
adoc.ActiveLayer.Lock = True
Zero = "0"
MakeSetLayer (Zero)
ErrorHandler:
If Err.Number <> 0 Then
'MsgBox Err.Description
End If
End Sub
