Thread: Change a schedule's category?
    2008-12
    West Roxbury, MA
    122
    Default Change a schedule's category?
    Hi,
    I use several types of custom area plans in my code analyses. I copied a specific type of area schedule from one project and pasted into another. However, its fields (including custom formula calculations) are not populating. It looks like I need to change the schedule's category to one of the other area categories in my project. How do I change a schedule's category?
    When you make a new schedule, one of the first things Revit does is have you select the category. How do I access this after a schedule has been created?
    Thanks,
    Derek
    2001-12
    Irvine, CA
    7,369
    Default Re: Change a schedule's category?
    It isn't possible. It would be nice if we could, at least for area schemes, since area schemes are a little different conceptually than doors and furniture. The underlying schedule process doesn't see it the way we do. We are able to see the abstract similarity, the software can't. Changing a category ordinarily would require rebuilding all the data columns of the schedule too, even though they might have a few fields in common, since much of the information would be different. In this case there isn't a shortcut.
    The API could probably be used to help, if you have experience with programming or access to one.
    2008-12
    West Roxbury, MA
    122
    Thanks Steve. I found that if I renamed the Area Scheme to match the same name from my previous file, then when I pasted the schedule in it populated nicely.
    2001-12
    Irvine, CA
    7,369
    Well that's fortunate, it's not so simple for other schedules. Just make sure you are seeing data for the correct scheme.
  1. Change Category, Change revision
    By Iwan van Wijk in forum Vault - Wish List
    Last Post: 2011-06-07, 07:57 AM
  2. change category
    By Ning Zhou in forum Revit - API
    Last Post: 2010-08-05, 09:27 PM
  3. How to change a Line category?
    By kklsara in forum Revit - API
    Last Post: 2008-09-17, 10:49 AM
  4. Need to change family category
    By barathd in forum Revit Architecture - General
    Last Post: 2005-10-17, 07:31 PM
  5. How can I change Category?
    By dgraue in forum Revit Architecture - General
    Last Post: 2005-08-27, 03:25 AM
