tedg
I assume this drawing with the raw attributes that you are inserting is actually named "TitleMark.dwg" and lives in the path you have in your routine?
you would be correct.
(command "insert" "*N:/Tuterj/AutoLISP/TitleMark.dwg" PT1 "" "")
tedg
And the attrubute tags are properly named to match up with your routine? (it appears that is the case based on your screen shot, but I'm just asking)
Yes, also correct. Per your previous suggestion I changed the block name from the two separate blocks it used to be to the block name that it is inserting it under, but the attribute definition tags are the same when i check them under properties.
(command "-attedit" "N" "N" "TitleMark" "NUMBER" "*" "#" mark_n)
(command "-attedit" "N" "N" "TitleMark" "TITLE" "*" "Title" title_u)
(command "-attedit" "N" "N" "TitleMark" "SCALE" "*" "Scale" scale_u)
tedg
You said this worked before your cad manager made it "without blocks", what was the block named before?
there were two blocks in the TitleMark drawing before they were exploded and purged. One block was solely for the Mark Number called 1det with the tag of NUMBER. The second block was called Title and had two attributes with the tags of Title and scale.
Should I be using a different command to edit these attribute definitions? OR should we not have left them as attribute definitions?
