Thread: Reverse fillets?
    2002-07
    Wilmington, DE
    86
    Unhappy Reverse fillets?
    Help! Does anyone know how to fix my corner cleanups on my walls? Some of the corners disappear instead of filleting? I may have changed something without realizing, but I can't fix it.
    2004-05
    808
    Default Re: Reverse fillets?
    There are several opportunities that cause this error.
    Different wall types with unresolved components.
    Walls of differing heights
    Walls inserted at differing elevations.
    Walls with graph lines defined differently.
    Wall endcaps interfering within the cleanup radius.
    Improper positioning of the mouth when activating the command.
  1. 2012: Issues with Fillets, snaps, dimnesion checks
    By mroth3270139 in forum AutoCAD General
    Last Post: 2012-02-06, 08:42 PM
  2. iPart Fillets not working
    By timothyjturner in forum Inventor - General
    Last Post: 2008-05-21, 07:01 PM
  3. Offset polylines get fillets
    By billn in forum AutoCAD General
    Last Post: 2007-06-18, 09:08 PM
