Thread: Assembly Failed - Need Help
    2013-09
    9
    Default Assembly Failed - Need Help
    Dear All,
    My name is hiandy and I am using Inventor Pro 2014.
    I am having a problem with assembling parts and the explanation would be as follows:
    1.There are 5 part files for the assembly on attachment. What I want is if I change dimensions of Duct Top part, the dimensions of the rest of other parts are changed too.
    2.Initially, I want to do it by using feature of Parameters. But, I have to change each dimension of each parts. So, to my opinion, it would be unproductive way.
    3.Then, I tried feature of Adaptivity. I was successful in doing it only for part Duct Top and Back Up Top. When I did it with third part U Type Fabric: flush constraint between part U Type Fabric with part Duct Top. I failed. I got an error message said that 'problem with relationship of those parts'
    Hope some of you can help me.
    Thank you.
    Regards,
    Hiandy
    Williamsport, PA
    641
    Default Re: Assembly Failed - Need Help
    The absolute easiest way to do something like this is to do multi-body solids within a single part file and then push out the assembly and individual parts (Manage>Make Components).
    I didn't understand why you made the pattern of holes the way you did?
    You could use Adaptive parts or parameter driven, but I recommend multi-body (which could also be parameter driven) as it is so easy and robust.
    2013-09
    9
    Dear JD Mather,
    Thank you for your reply.
    Before discussing my topic, I would like to convey my deep apology to you, all AUGI members and moderator of this forum because I accidentally already posted 2 threads with the same topic: 'Assembly Failed - Need Help' and 'Assembly and Adaptivity'. It was purely caused by my carelessness.
    Going back to my topic. I would like to thank you for your advice and solution. I still remember you that long time ago you were the one who helped me with the solution of starting point of the hole.
    My questions:
    -For Pattern of holes
    Would you kindly let me know the right way to do it?
    -For Assembly
    The final goal I want to achieve with my assembly is to be able for me to do the changes on dimensions on 1 part only (for example on 'Duct Flange Top' part). The changes will affect to the dimensions of other parts.
    Following video more or less represents my wish: http://www.youtube.com/watch?v=x1NNFNqUtzM
    To my guess, I can get what I want by doing something like this: http://www.youtube.com/watch?v=Q8Qt5hs7xpE
    Dear JD Mather, would you let me have your confirmation whether I can use methods on second video to reach my goal.
    Look forward to receiving your reply.
    Thank you.
    Regards,
    Hiandy
  1. Replies: 1
    Last Post: 2012-05-28, 04:58 PM
  2. Replies: 1
    Last Post: 2012-05-28, 04:56 PM
  3. Run Failed
    By abechard in forum Green Building Studio - General
    Last Post: 2009-12-28, 09:05 PM
  4. Replies: 2
    Last Post: 2006-06-30, 08:31 PM
  5. Assembly Plant Filter-Regulator-Lubricator Assembly
    By dcbenson001 in forum AutoCAD Gallery
    Last Post: 2005-06-14, 01:40 PM
