So, I have started at a new company and they are using revit 2014.
I have discovered that its snail pace slow on this machine, and after doing a bit of research I see that my system specs put me around mid-range recomendations from Autodesk.
16gb Ram, Xeon CPU E5-1620 0 @ 3.60 GHz
and as the title suggests, using an NVIDIA Quadro 2000 card.
As far as the recommendations go, system specs should not be a problem but that being said, Revit is running very slowly, often gets a bit glitchy with the screen redrawing and blocking out the top half of the window (until I minimize and maximize the window) and turning and navigating a large model is slow, drawing & modelling is close to the point of un-workable very slow and frustrating.
Anyone else had similar problems, know a way to optimize or reduce it, or have any suggestions??
Reached about the limit of my knowledge on the matter and I have not been able to find much on the topic that has helped me out.
