Once a batch print is started in Revit, how is it canceled? If a sheet size is wrong, or a batch print was initiated when a single sheet was intended for example. How do you cancel the batch print?
While printing is active you should see a Cancel button in the bottom left corner of the interface (Status Bar). It may disappear occasionally but if you click when it appears it should cancel the remainder of the print job...unless it manages to send them all before you get to it.
Frankly this is a bug that autodesk should really fix.
I've found that no matter what you did the last time you printed, if you open a view and don't click someone in the view, you just go to print, it always seems to chose the selected views/sheets option. Why can't it remember what I did the last time. Autocad had this nice little feature that saved the setup from the last print dialog box. Why hasn't the Revit Team figured that one out.
Also cancel should cancel the entire process. I shouldn't need to cancel individual sheets. Instead of new "Features", maybe they should focus on fixing the broken stuff before they create more broken stuff.
Just my thought.
In the R2 version of 2016 this is the case. It will let you cancel the whole batch with a few other cool features.
