Associative text not showing on sheets. HELP PLEASE!!
"Associative" or "annotative"? If the latter, is the drawing scale of the sheet one of the scales assigned to the text? If you are viewing model space text via a viewport, is the viewports annotation scale (which is usually the same as the drawing scale, but can be set to be different) one of the scales assigned to the text? If the text does not have the same scale, it will not show. (I assume you have checked to make certain that the layer on which the text is placed is turned on, thawed and, where applicable, viewport thawed.)
