Well after playing with the splash screen program, I liked the fact you could display image files in a dialog, which LISP cannot do without using slides.
I also thought it might be nice to create a Slide Show, using a timer and a listbox.
So here it is on you tube.
http://www.youtube.com/watch?v=NVS59...ature=youtu.be
If you like what you see you could download the attachments.
Here is the LISP file that calls the new .net function
(defun C:Slides ()
(slideshow "c:\\slideshow\\testbitmap.dwg" "photo1.jpg" "photo2.jpg" "photo3.jpg" "photo4.jpg" "photo5.jpg")
(defun C:Slides2 ()
(slideshow (list "c:\\slideshow\\testbitmap.dwg" "photo1.jpg" "photo2.jpg" "photo3.jpg" "photo4.jpg" "photo5.jpg"))
This is the dialog appearance:
Panel1(Image), Button1(OK), Button2(Cancel), Button3(SlideShowOnOff), Listbox1(ImageFiles)
This is the Form1 Code
Imports Autodesk.AutoCAD.DatabaseServices
Public Class Form1
''' <summary>
''' OK Button
''' </summary>
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
SlideShowClass1.objTimer.Stop()
SlideShowClass1.strImageFullName = ListBox1.SelectedItem.ToString
Close()
End Sub
''' <summary>
''' Cancel Button
''' </summary>
Private Sub Button2_Click(sender As Object, e As EventArgs) Handles Button2.Click
Close()
End Sub
''' <summary>
''' Turn Slide Show On and Off Button
''' </summary>
Private Sub Button3_Click(sender As Object, e As EventArgs) Handles Button3.Click
If SlideShowClass1.blnSlideShowOn = True Then
SlideShowClass1.blnSlideShowOn = False
Button3.Text = "Turn Slide Show On"
Else
Button3.Text = "Turn Slide Show Off"
End If
End Sub
''' <summary>
''' List Box Selection Callback changes image of Panel1 to image file or drawing thumbnail
''' </summary>
Private Sub ListBox1_SelectedIndexChanged(sender As Object, e As EventArgs) Handles ListBox1.SelectedIndexChanged
Try
SlideShowClass1.strImageFullName = Me.ListBox1.SelectedItem.ToString
If System.IO.Path.GetExtension(SlideShowClass1.strImageFullName).ToUpper = ".DWG" Then
Dim objDatabase As New Database
objDatabase.ReadDwgFile(SlideShowClass1.strImageFullName, _
FileOpenMode.OpenForReadAndAllShare, False, Nothing)
Me.Panel1.BackgroundImage = objDatabase.ThumbnailBitmap
Else
Me.Panel1.BackgroundImage = System.Drawing.Image.FromFile(SlideShowClass1.strImageFullName)
End If
Me.BringToFront()
Catch ex As Exception
End Try
End Sub
End Class
and this is the class code
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Imports System.Windows.Forms
Imports objACADApplication = Autodesk.AutoCAD.ApplicationServices.Application
Public Class SlideShowClass1
Private tpvNil As New TypedValue(LispDataType.Nil, -1)
Public Shared objForm As New Form1
Public Shared objTimer As System.Windows.Forms.Timer
Public Shared blnSlideShowOn As Boolean = True
Public Shared strImageFullName As String
''' <summary>
''' LISP Function to show slide show of images (or drawing thumbnail images)
''' </summary>
<LispFunction("SlideShow")> _
Public Function SlideShow(ByVal rbfArguments As ResultBuffer)
Try
Dim arrArguments As TypedValue() = rbfArguments.AsArray
If arrArguments.Length > 0 Then
Dim strImageFullName, strImageName As String
' Dim tpvItem As TypedValue()
If Not objForm Is Nothing Then objForm = New Form1
With objForm.ListBox1
If .Items.Count > 0 Then .Items.Clear()
For intCount = 0 To arrArguments.Length - 1
If arrArguments(intCount).TypeCode = 5005 Then
strImageName = arrArguments(intCount).Value.ToString
strImageFullName = HostApplicationServices.Current.FindFile(strImageName, _
objACADApplication.DocumentManager.MdiActiveDocument.Database, _
FindFileHint.Default)
If strImageFullName IsNot Nothing Then .Items().Add(strImageFullName)
End If
Next
strImageFullName = ""
If .Items.Count = 0 Then Return tpvNil
.SelectedIndex = 0
TimerInitialize(2000.0) '<- Milliseconds
If objForm.ShowDialog() = DialogResult.Cancel Then
Return tpvNil
End If
End With
End If
Return New TypedValue(LispDataType.Text, strImageFullName)
Catch ex As System.Exception
End Try
Return tpvNil
End Function
''' <summary>
''' Function to initialize the forms timer
''' </summary>
Private Function TimerInitialize(ByVal dblMilliseconds As Double)
Try
If objTimer Is Nothing Then
objTimer = New System.Windows.Forms.Timer
AddHandler objTimer.Tick, AddressOf TickHandler
End If
objTimer.Interval = CType(dblMilliseconds, Integer)
objTimer.Enabled = True
objTimer.Start()
Return True
End Try
Return False
End Function
''' <summary>
''' Timer Callback Function to switch image
''' </summary>
Private Sub TickHandler(ByVal sender As Object, ByVal e As System.EventArgs)
ImageChange(objForm.ListBox1)
End Sub
Public Delegate Sub ListBoxDelegate(ByVal objListBox As ListBox)
''' <summary>
''' Function to Change Image in Listbox to next image
''' </summary>
Public Sub ImageChange(ByVal objListBox As ListBox)
objForm.BringToFront()
If objListBox.InvokeRequired Then
objListBox.Invoke(New ListBoxDelegate(AddressOf ImageChange), objListBox)
Else
If blnSlideShowOn Then
With objForm
If .ListBox1.Items.Count > 0 Then
If .ListBox1.SelectedIndex < .ListBox1.Items.Count - 1 Then
.ListBox1.SelectedIndex += 1
Else
.ListBox1.SelectedIndex = 0
End If
End If
End With
End If
End If
End Sub
End Class
I should mention that I coded this in Visual Studio 2013 and used AutoCAD 2014 for the code package
