Results 1 to 9 of 9
Thread: Crazy rendering result... I don't understand what the problem is
    2014-01
    Default Crazy rendering result... I don't understand what the problem is
    Hi All!
    My first post here but have been reading for quite a bit. I've encountered a problem I would like your advice on:
    The second image is the problem. I have rendered another room in the same project with the same settings and it turns out fine (first image).
    Does anyone know what the problem is?
    Vancouver, BC Canada
    3,744
    Default Re: Crazy rendering result... I don't understand what the problem is
    Welcome to the forums.
    Any chance there's a mirror above that sink? Looks to me like you have light reflecting off the mirror and bouncing all over the room. I'm no rendering expert but the reflections settings might be affecting how all the 'flare' spots are appearing on the wall.
    Try turning off the mirror and see what happens.
    2014-01
    Quote Originally Posted by Dimitri Harvalias View Post
    Thank you for your advice Dimitri. I don't have a mirror but I have glossy tiles. I tried reducing the number of reflections but it made it worse, so then I tried to increase number of indirect illumination bounces from 2 to 3 and the difference was marked. So then I tried increasing it to 4 and there was no further improvement but rendering time was now over 5 minutes up from 1.5 minutes originally.better.jpg
    2002-09
    Madison, WI
    5,506
    If I had to take a guess, check the settings for the sun. Seems bright and seems to be very direct.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    2005-04
    Saintlouis Missouri
    479
    To me, it looks like the light is at 180 degrees or more. try not to have it so bright and change the type of light source you are using. Before that turn off that light and place a STUDIO LIGHT in the scene. It is a general light just so you can omit light in a space without picking an actual light. I is not hosting to anything and can adjust the height. render with that and see if the scenes lighting on all your materials change. If so, then it def is something with the actual light you chose.
    2014-07
    @vitality: Is the quality for the renderings set a high or best? If not then do so for best quality.
    Change the background from sky to background colour. Choose a pale blue. If you want to use a background image you can do that too.
    Adjust the highlights to 0 or near 0.
    Adjust the shadows to lowest possible setting.
    Change the sun to winter months late evening/early morning.
    If you don't want to add studio lights then using go ahead with daylight portals, even if it takes a long time.
    2005-04
    Saintlouis Missouri
    479
    Add the basic studio light and place it where you want and turn off the sun. Then you can play with the location of the light. The studio light is just light and does not show as a source
    I could stop if I wanted to rbcameron1's Avatar
    2008-09
    Nebraska & Iowa
    378
    Do you have any reflective metal material in the scene?
    RB Cameron, AIA, LEED AP, EDAC
    BIM Coordinator - VDC Coordinator - Visualization Artist
    Download Healthcare Revit+3dsMax Models
    Download Revit+3dsMax Models
    2014-03
    16
    Did you set the lighting scheme to "Interior"? (In View>Render)
  1. Replies: 3
    Last Post: 2012-11-07, 03:34 AM
  2. Problem, Force in point: wrong result
    By smm.144 in forum Robot Structural Analysis
    Last Post: 2010-05-09, 06:51 PM
  3. Schedule result problem
    By kmelchor in forum ACA General
    Last Post: 2009-02-13, 05:04 PM
  4. Problem with the result of vlax-get-property
    By GreyHippo in forum AutoLISP
    Last Post: 2006-08-24, 07:46 PM
  5. Replies: 0
    Last Post: 2006-07-19, 05:36 PM
