Thread: Floor plan callout in a section view reference?
    2014-01
    Default Floor plan callout in a section view reference?
    I have drawn a callout of a pilaster detail in plan. I have added some details to it and placed it on a sheet. I would like to reference this callout in a section view by using a section marker and rotating it horizontally. However, because the callout is a "floor plan" view when I try to "reference other view:" it does not come up on the list for me to click. If anyone has any ideas on how to make this work or another way of referencing the floor plan callout please let me know. Thanks!
    2012-01
    7
    Default Re: Floor plan callout in a section view reference?
    Quote Originally Posted by rmercer526647 View Post
    +1
    Same question. Short from 'faking it' is there a viable solution?
    2002-09
    Madison, WI
    5,687
    Nope,
    The answer is what it is. And it's basically correct. Follow the line of thinking. When you go thru a set of drawings, you look at the plan and then go to the details and sections. You generally don't look at all the details and then try to figure out where they are cut. Linear method.
  1. Shared Parameters for Elevation Mark, Section Mark, Callout Head & View Reference Families.
    Last Post: 2021-04-21, 08:30 PM
  2. 2016: Family not selectable in floor plan or Section view
    By mit81 in forum Revit MEP - Families
    Last Post: 2015-09-09, 01:13 PM
  3. 2013: Have you ever lost a section view callout on a plan view?
    By kmcglothlin in forum Revit MEP - General
    Last Post: 2013-11-21, 05:24 PM
  4. 2012: callout reference - not showing the plan
    By utakecare2003 in forum Revit Architecture - General
    Last Post: 2012-10-12, 06:19 PM
  5. Callout in section and section in plan annotation
    By t1.shep in forum Revit Architecture - General
    Last Post: 2007-09-25, 03:34 PM
