Thread: Creation of local file and synchronization error
    2012-07
    Default Creation of local file and synchronization error
    We are currently working on a huge project (200k sqm), single building and we have segregated our model into multiple files (basement, upper levels, documentation, site) for better management of file size. However, as we are moving deeper into the job, we seem to have some issues with creation of local files (greyed out at times) and synchronizing (often fails). Anyone out there facing similar issues or have any valuable advice?
    Digital Delivery Director Brian Myers's Avatar
    2003-02
    Stillwater, Oklahoma
    1,819
    Default Re: Creation of local file and synchronization error
    We used to have the issue with grayed out local files. It had something to do with not all the users pathed the same way to the file.
    http://revitclinic.typepad.com/my_we...rayed-out.html
    In a few of our 2012 projects it also seemed to occur if one user was using Revit MEP, saved the file, and another user tried to open it in Revit Structure. My guess, it's related to the user path mentioned above.
    2002-09
    Madison, WI
    5,687
    We've run into this a few times on my current project. We've noticed it more when we get more than 6-7 people actively working on it. We also have a bunch of people that were using RDP machines that we were thinking caused the central file to "stall" for a moment. If the user waited a few mins and tried again, it seemed to fix itself.
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    According to Autodesk tech help, R13 and R14 handle linking differently internally. We were having nasty sync problems in R13. Links were being constantly unloaded when remote locations saved, then the sync would fail, leaving us with a crippled CF.
    The solution was:
    1) Use UNC filenames for all links. A pain - but it solved the problem
    2) Insert the link to the central file directly, not from a local.
    The users will all have to get out while you work with Central, and all will have to make new locals, but these two steps solved the problem. Apparently, if the link filename is not exactly the same at all locations, Revit gives up and unloads the locals.
  1. Transparent Local file creation
    By dbaldacchino in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2017-06-21, 04:29 PM
  2. Transparent Local File Creation - GUI (v5) *UPDATED*
    Last Post: 2017-01-09, 02:50 AM
  3. 2014: Auto Synchronization to central file upon opening a local Revit file
    By manoshj1534948 in forum Revit - API
    Last Post: 2014-02-05, 04:33 AM
  4. Local File Incompatible with Central File - Revit 2010 Error??
    By ekneer in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-02-18, 03:51 PM
  5. Local Files: program to delete local file and create a new local file
    By mailshanegross in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2009-06-03, 02:29 AM
