Results 1 to 10 of 11
Thread: LISP Not Working After Opening A Drawing - Using ACADDOC.LSP
    2001-11
    236
    Default LISP Not Working After Opening A Drawing - Using ACADDOC.LSP
    Sad in 2014 I am still fighting with the better way to load all my lisps. Maybe I am not typing the "right" search keyword.
    I am trying to start using the ACADDOC.LSP. Created one, put it in the main folder with ACAD.EXE, open AutoCAD (2014),
    all the LISPs I imputed in ACADDOC work.
    However, when I open a drawing file, no LISP work. What am I failing to do?
    Typical entry in ACADDOC.LSP is:
    (load "L:\\autocad\\profiles\\oka\\okacadd\\lisp\\CW.lsp" "CW Failed to Load.")
    OR
    (load "CW.lsp" "CW Failed to Load.")
    Typical LISP location example:
    L:\AutoCAD\Profiles\Oka\OkaCADD\LISP\CW.LSP
    I have the location of all my LISP files in the search path. Does it really mater where the Support File Search Path is in the list?
    I tried locating it in the middle and at the end, still opening a file disables the LISPs in the ACADDOC.LSP.
    Thanks.
    5,714
    Default Re: LISP Not Working After Opening A Drawing - Using ACADDOC.LSP
    Did you configure the new SECURELOAD, and TRUSTEDPATHS system variables?
    If not, see the link in my signature for more information.
    HTH
    2001-11
    236
    HTH
    No, I did not configure the SECURELOAD (did not know it exists).
    1. Bye the way, I just did a full search and found these: ACAD2014.LSP & ACAD2014DOC.LSP. Am I using the wrong "...DOC.LSP" file all along?
    Guess the "ACADDOC.LSP" file is from previous versions?
    2. Should the "...DOC.LSP" file be located in the main AutoCAD folder where the ACAD.EXE is or should it be in the SUPPORT folder?
    Thanks again.
    5,714
    Quote Originally Posted by omorah View Post
    No worries; these system variables were introduced in 2014.
    Acad####.lsp, and Acad####Doc.lsp are AutoCAD-owned files that have been part of the product's startup mechanism for longer than I've know what AutoCAD is... Do not modify these files. Also worthy of note, is that starting with 2014, these files can no longer be moved to a custom folder. If not found in the default folder, they are not loaded at startup at all - even if moved to another folder within the SFSP.
    Continue to employ the user-owned Acad.lsp, and AcadDoc.lsp files as needed, as these will not be potentially overwritten with each product update, etc. These files may be located anywhere within the Support File Search Path (SFSP), but it is generally recommended that you place them within a folder at the top of your SFSP to avoid accidental loading of the wrong one by mistake, as only the first one found within SFSP is loaded.
    HTH
    2001-11
    236
    With your replies, it looks like I am doing what I am supposed to do (except not doing anything with ACAD.LSP).
    - I have the ACADDOC.LSP in: "C:\Program Files\Autodesk\AutoCAD 2014\ACADDOC.LSP"
    - All the LISPs in ACADDOC.LSP are on the network folder which in turn is in my Support File Search Path.
    - When AutoCAD is opened, the routines work.
    - When I open a drawing file, none of the routines work.
    - But when I use the Load/Unload Applications & Startup Suite, all the routines work.
    2,095
    Time to do some error checking ie. are they actually being loaded? If not, why? Secure load fail? Invalid LISP file? Invalid path? Proper ACADDOC.LSP file being loaded? Third-party program like AutoPLANT or PDMS P&ID preventing your stuff from being loaded?
    Stupid question time: SDI or multiple document mode? I've had problems with SDI mode and ACADDOC.LSP before.
    (other)Stupid question: you don't have a virus problem with the replicating ACAD/ACADDOC.LSP files do you?
    5,714
    Adding to Dgorsman's comments, try using FINDFILE LispFunction in each drawing to verify that YOUR AcadDoc.lsp file is found first.
    9,803
    Note: Acaddoc.lsp is loaded each time a drawing is loaded. Acad.lsp is only loaded once at application launch (unless you set acadlspasdoc = 1, which is not recommended) [1]
    My suggestion is to create a new directory (maybe C:\CADSTUFF) and put acaddoc.lsp in there, THEN add this path to the TOP of your support file search path.
    External lisp files do not have to be in the SFSP, but it doesn't hurt.
    ;;;At the TOP of your acaddoc.lsp file, put this:
    (princ "\nLoading acaddoc.lsp")
    ;;;At the BOTTOM of the file, put this:
    (princ "\nAcaddoc.lsp successfully loaded")
    Look for these lines to be printed on the command line when you open AutoCAD and when you open a drawing.
    If the top one is printed, then you know the file is being loaded.
    If the bottom one is missing, then something in your code is failing.
    2001-11
    236
    Quote Originally Posted by dgorsman View Post
    In my previous post, I showed you all the wrong information. When I looked at the ACADDOC.LSP, I had spaces before quotes where they should not be so I got all the imputed lines corrected. Still that did not fix the issue (but at least one error fixed).
    This is the icing on the cake to show whether the file loaded successfully!
    Did some 'house keeping' with file paths making sure all paths are valid and pointing to the correct reference.
    HTH
    The SECURELOAD and TRUSTEDPATHS were the culprits. I set my SECURELOAD to "2" and added the LISP file path to the trusted path referenced folder.
    Voila, all is well now and working after opening a drawing file.
    Folks, I sure appreciate all your help and time in helping me solve this issue.
    Thanks.
    5,714
    Thanks.
    No worries; We're happy to help.
    Cheers
  1. View XREFS in a Drawing Without Opening the Host Drawing
    Last Post: 2013-11-27, 01:23 PM
  2. Replies: 18
    Last Post: 2008-11-14, 12:40 AM
  3. Replies: 2
    Last Post: 2008-07-09, 12:17 AM
  4. Replies: 10
    Last Post: 2006-07-25, 11:43 PM
  5. Font changes while working in DWG or when Opening DWG
    By lamarche22 in forum AutoCAD LT - General
    Last Post: 2006-06-20, 05:43 PM
