Results 1 to 9 of 9
Thread: Using SETQ to assign a block to a variable
    2011-09
    308
    Default Using SETQ to assign a block to a variable
    Hey gang,
    I'm writing a LISP routine to create a slope arrow. At one point I need to assign a block to a variable, but that block is in another drawing.
    I could use this line if it was just one drawing that made up the block:
    (setq block1 "arrow.dwg")
    But what I want is to have all the blocks I need for the routine in one drawing and use something like this:
    (setq block1 "arrowblock from blocks.dwg")
    FYI the reason I want to do it this way is because I need to have these blocks come in with all possible annotations scales pre populated and I can't seem to do that when they are separated out into individual drawings. If you know how to do that... let me know.
    Any help is, as always, greatly appreciated.
    -JP
    2013-07
    66
    Default Re: Using SETQ to assign a block to a variable
    Quote Originally Posted by jpcadconsulting347236 View Post
    Hey gang,
    -JP
    Whatever is before ".dwg" when referencing a block is the block's name. You can't just on-the-fly name these per your needs. That is in effect what (setq) is doing.
    Additionally, as long as the blocks reside in a directory that's within your save file search paths, you're able to call it with just the block name without the ".dwg" if you're attempting to create or add to a selectionset via (ssget).
    Here's an example I just finished doing.
     (if (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 2 a2))))
        (progn
          (setq pfst (getvar 'PICKFIRST))
          (setvar 'PICKFIRST 1)
          (sssetfirst nil ss)
          (c:burst)
          (setvar 'PICKFIRST pfst)
    (princ)
    );progn
    You can see here that I'm using the a2 variable to represent a block name.
    I know all of the blocks that may be represented by "a2" are within my search paths, so the ssget is successful in finding them with the parameters shown
    2011-09
    308
    Thanks bhull1985403354,
    maybe I should have been more precise... (or maybe I just don't understand the code you posted)
    I have a drawing called slopeblocks.dwg which contains 3 blocks:
    slopeorigin
    slopevalue
    slopearrow
    I'm trying to write a lisp routing that draws a line and then inserts those 3 blocks at the start, midpoint and end of the line respectively.
    I can do it if the blocks are each a separate file, but then I can get them to bring in the annotation scales.
    All drawing are in my search path and the lisp would always pull the same blocks form the same drawing.... no need for user input other than picking the start and end points of the line.
    For reference, here is the code (which almost works) using separate drawings:
    (defun c:slope (/ block1 block2 block3 p1 p2 p3 dist ang angdeg)
    (setq block1 "slopeorigin.dwg")
    (setq block2 "slopearrow.dwg")
    (setq block3 "slopevalue.dwg")
    (setq p1 (getpoint "\npick high point of slope: "))
    (setq p2 (getpoint "\npick low point of slope: "))
    (setq dist (distance P1 P2))
    (setq ang (angle P1 P2))
    (setq p3 (POLAR P1 ANG (/ DIST 2)))
    (setq angdeg (* (/ ang pi) 180.0))
    (command "line" p1 p2 "")
    (command "-insert" block1 p1 "1" "1" angdeg "")
    (command "-insert" block2 p2 "1" "1" angdeg "")
    (command "-insert" block3 p3 "1" "1" angdeg "")
    (princ)
    -JP
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    You could insert your container drawing into your current drawing. Once it is in your drawing, the other blocks would then be available.
    2013-07
    66
    Yeah, I tried to post here twice already and the webpage keeps eating them. Dang IE!!
    Anyhow, just try this:
     (setq block1 "slopeblocks")
     (if (setq ss (ssget "_X" (list (cons 0 "INSERT")(cons 2 block1))))
        (progn
          (sssetfirst nil ss)
          (c:burst)
    (princ)
    );progn
    );if
     (princ)
    Try that, assumes you already have express tools installed.
    2011-09
    308
    Ok, thanks. Much closer.
    However, this inserts all three blocks contained in slopeblocks.dwg at the first picked point (and actually, just a bit off that point.)
    Thoughts?
    Thanks for all your help with this.
    -JP
    2013-07
    66
    True,
    you can assign the midpoint and endpoint of your line to variables
    then issue a command "move" on the blocks that are now in your drawing, perhaps re-adding block1/block2/block3 , and tell it to move block1 to endpoint1, move block2 to midpoint, move block3 to other endpoint.
    HTH
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    I think what Opie meant was something like
     (command "-insert" container.dwg (command))
    would add the blocks to the drawing without actually inserting them anywhere. Afterwards insert "slopeorigin.dwg", "slopearrow.dwg", & "slopevalue.dwg" where you want them.
    2011-09
    308
    Thanks for all your help everyone! I've got it working well in this form (except for one issue regrading text alignment which I'll post separately):
    (defun c:slope (/ origin slope arrow1 p1 p2 dist ang angdeg p3)
    (setq origin "slopeorigin.dwg")
    (setq arrow1 "slopearrow.dwg")
    (setq slope "slopevalue.dwg")
    (command "-insert" origin p1 "1" "1" angdeg "")
    (command "-insert" slope p3 "1" "1" angdeg "")
    (command "-insert" arrow1 p2 "1" "1" angdeg "")
    (princ)
  1. Replies: 14
    Last Post: 2018-11-10, 07:28 PM
  2. Replies: 4
    Last Post: 2015-08-29, 04:40 AM
  3. error: bad variable name in SETQ?
    By stusic in forum AutoLISP
    Last Post: 2013-05-21, 05:46 PM
  4. COND Statement to Setq Variable
    Last Post: 2012-04-05, 08:47 PM
  5. setq Selection Set to a variable
    By gisdude in forum AutoLISP
    Last Post: 2006-05-30, 03:05 PM
Tags for this Thread
