Thread: File Multi Selection Dialog (and Folder Select)
    2000-09
    Honolulu HI
    1,109
    Default File Multi Selection Dialog (and Folder Select)
    Hey Group,
    While I was playing around with the folder selection routines I started playing around with a multi select file dialog box functions.
    In LISP the getfiled expression doesn't allow the user to specify multiple select.
    I played around with several file select dialogs and found the one from Autodesk.Windows is actually quite good.
    I created a function to check the arguments of the lisp function and have a separate function to convert the string array output from the dialog into a result buffer of lispdatatype.text items.
    Like most of my lispmethod functions, I separate the .net function from the lispmethod function... that way the .net code could be used independently.
    Imports Autodesk.AutoCAD
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.EditorInput
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.ApplicationServices
    Imports Autodesk.AutoCAD.Windows
    Public Class FileSelectClass1
        ' LISP Function syntax:
        ' (FileSelect "Select Folder" "C:\\ACAD\\LISP\\" "" (+ 4 8 32 64 128 256 512 1024 2048))
        ' (FileSelect "Select Drawing" "C:\\ACAD\\LISP\\TEST2.DWG" "dwg" (+ 4 8 32 64 128 256 512 1024))
        ' (FileSelect "Select Drawings or JPG" "C:\\" "dwg;jpg" (+ 4 8 32 64 128 256 512 1024 4096))
        ''' <summary>
        ''' LISP Function for a file dialog box that can be set using flags to
        ''' select folders, multiple files or files. See bit codes descriptions
        ''' for flags below.
        ''' </summary>
        ''' <param name="rbfArguments"></param>
        ''' <returns>List of selected files or Folders</returns>
        <LispFunction("FileSelect")> _
        Public Function FileSelect(ByVal rbfArguments As ResultBuffer)
            Try
                Dim strReturn() As String
                If rbfArguments Is Nothing Then
                    strReturn = FileSelect()
                Else
                    Dim arrArguments As TypedValue() = rbfArguments.AsArray
                    strReturn = FileSelect(ArrayValue(arrArguments, 0), _
                                            ArrayValue(arrArguments, 1), _
                                            ArrayValue(arrArguments, 2), _
                                            ArrayValue(arrArguments, 3))
                End If
                If strReturn IsNot Nothing Then
                    Return StringArrayToResultBuffer(strReturn)
                End If
            Catch exception As Exception
                System.Diagnostics.Debug.Write(exception.ToString())
            End Try
            Return Nothing
        End Function
        ''' <summary>
        ''' .NET function to display a file select dialog box and return its value
        ''' </summary>
        ''' <param name="strTitle"></param>
        ''' <param name="strFileName"></param>
        ''' <param name="strFilter"></param>
        ''' <param name="intOpenDialogFlags"></param>
        ''' <returns> String array of selected item s</returns>
        Public Function FileSelect(Optional ByVal strTitle As String = "File Select Title", _
                                   Optional ByVal strFileName As String = "c:\\", _
                                   Optional ByVal strFilter As String = "dwg", _
                                   Optional ByVal intOpenDialogFlags As Int16 = 4
            Try
                ' Flag Bit Codes
                ' .AllowAnyExtension = 4
                ' .SearchPath = 8
                ' .DefaultIsFolder = 16
                ' .DoNotTransferRemoteFiles = 64
                ' .NoUrls = 128
                ' .ForceDefaultFolder = 256
                ' .NoFtpSites = 512
                ' .NoShellExtensions = 1024
                ' .AllowFoldersOnly = 2048
                ' .AllowMultiple = 4096
                Dim openFileDialog As New  _
                    Autodesk.AutoCAD.Windows.OpenFileDialog(strTitle, strFileName, strFilter, "DialogName", _
                                                intOpenDialogFlags)
                With openFileDialog
                    If .ShowDialog() = System.Windows.Forms.DialogResult.OK Then
                        Return .GetFilenames
                    End If
                End With
            Catch ex As System.Exception
            End Try
            Return Nothing
        End Function
        ''' <summary>
        ''' Function to an get item in the array.
        ''' </summary>
        ''' <param name="arrArguments"></param>
        ''' <param name="intItem"></param>
        ''' <returns> Item in array or Nothing for error </returns>
        Public Function ArrayValue(ByRef arrArguments As TypedValue(), ByVal intItem As Integer)
            If intItem < arrArguments.Length Then Return arrArguments(intItem).Value
            Return Nothing
        End Function
        ''' <summary>
        ''' Function to return a resultbuffer of typedvalue lispdatatype.text items
        ''' </summary>
        ''' <param name="strArguments"></param>
        ''' <returns>Result Buffer of text items </returns>
        Public Function StringArrayToResultBuffer(ByVal strArguments() As String)
            Try
                If strArguments IsNot Nothing Then
                    Dim rbfResult = New ResultBuffer(New TypedValue(LispDataType.ListBegin, -1))
                    For intItem = 0 To strArguments.Length - 1
                        rbfResult.Add(New TypedValue(LispDataType.Text, strArguments(intItem)))
                    Next intItem
                    rbfResult.Add(New TypedValue(LispDataType.ListEnd, -1))
                    Return rbfResult
                End If
            End Try
            Return Nothing
        End Function
    End Class
    AutomateCAD
    2000-09
    Honolulu HI
    1,109
    Default Re: File Multi Selection Dialog (and Folder Select)
    I have had trouble posting new threads for some reason, so I copied this thread and changed the title/revised posts so it could be posted.
    I asked Opie to look into the problem with posting threads.
    That is why the date appears wrong.
    AutomateCAD
  1. Replies: 13
    Last Post: 2018-03-13, 12:52 AM
  2. Replies: 0
    Last Post: 2011-05-30, 07:07 AM
  3. multi select dialog box
    By rwbaker in forum VBA/COM Interop
    Last Post: 2006-03-10, 08:18 PM
  4. Open File Dialog Folder Addition
    By barathd in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-02-07, 04:44 PM
  5. File selection dialog box
    By jgratton in forum CAD Management - General
    Last Post: 2005-01-20, 08:38 PM
