Thread: Share selection filters
    2015-10
    215
    Default Share selection filters
    Is there a way to share selection filters that are saved in the filter dialog?
    9,805
    Default Re: Share selection filters
    Do you mean share with another user?
    When you save a filter, it writes a file named "filter.nfl" and it should be located in %appdata%\Roaming\Autodesk\<product>\<language>\Support
    You can copy this file to the same location on another machine.
  1. Selection Set Filters
    By stusic in forum AutoLISP
    Last Post: 2012-09-16, 09:59 PM
  2. Selection set filters? Can anybody help?
    By ReachAndre in forum AutoLISP
    Last Post: 2009-06-29, 03:09 PM
  3. Selection Set filters
    By amaser in forum VBA/COM Interop
    Last Post: 2008-09-17, 02:43 PM
  4. User Defined Selection Filters - WHERE??
    By Batman in forum Revit Architecture - General
    Last Post: 2006-05-08, 01:58 AM
  5. better selection filters
    By Martin P in forum Revit Architecture - Wish List
    Last Post: 2003-05-02, 09:07 PM
