I have a dwg with numerous polylines that represent sections of sewer force main in a collection system.
After doing a data extraction of the various line types that represent the different sizes, I noticed some of the parameters
needed to be edited. the one parameter that is unique is the length, so I thought by using the quick select dialog box I
would be able to highlight that one polyline by length. After selection all the correct selections and picking "equal to" and
imputing the actual length, let's say "3114.28", I get 0 entities found. After numerous attempts and going online to find
a solution and searching this forum, I finding came up with the solution by imputing the search as "greater than 3114" and then
going back imputing "less than 3115" and it highlighted the correct polyline.
I guess my question is, can you only use whole numbers for a length search and not real numbers? In the this scenario.
Also the filter command did not give me the option of filtering for a specific length of a polyline.
Any thoughts, comments, and/or solutions would be greatly appreciated.
Thank you.
Robert
