Thread: Pipe Accessory detail component not showing
    2014-02
    2
    Default Pipe Accessory detail component not showing
    I am trying to create a ball valve that looks like the following:
    To get the filled in portion, I created a detail family with a fill. All appears to be well, until I load the family into a project. Then the detail family disappears - no ball is seen. I've triple checked all the view settings and everything appears to be in order. The lines remain, but the filled ball is gone. This happens when I am looking from the floor plan view.
    If I look at the valve from an elevation, rotating the valve to see it properly, the filled ball is back.
    If I change the family type from Pipe Accessories to something else, for example, Duct Accessories, the filled ball appears as it should.
    If I insert this family into a Mechanical Equipment family, then insert into the project, all appears as it should.
    Is there a reason that Pipe Fittings and Pipe Accessories do not show detail components in plan views?
    I'm using Revit 2014 and I've attached the valve family in question.
    2012-11
    Sin City
    29
    Default Re: Pipe Accessory detail component not showing
    I work for a content provider, so Revit MEPs are all we use (so your family is visible off the bat); but try changing the OC of the detail to match (23.65.55.14.14).
    On a side note, if you're using generic Revit valves as a reference;
    - Create the valve vertical (perpendicular to the horizontal plane)
    - One set of line should suffice (Ref Level)
  1. 2012: Vertical Pipe not showing correctly in Medium detail level
    By jackcai1026 in forum Revit MEP - General
    Last Post: 2012-07-06, 11:42 PM
  2. 2012: Arrange options not showing up for one detail component
    Last Post: 2012-02-27, 11:57 PM
  3. tag for pipe accessory
    By alan.jackson in forum Revit MEP - General
    Last Post: 2008-04-22, 05:00 PM
  4. Nested detail component not showing when joined w/ other family.
    By archjake in forum Revit Architecture - Families
    Last Post: 2007-01-24, 12:50 AM
  5. Detail Component in Curtain Panel showing through anything.
    By tomnewsom in forum Revit Architecture - General
    Last Post: 2006-10-12, 11:47 PM
Tags for this Thread
