Results 1 to 6 of 6
Thread: Error VBA DimAligned
    2014-01
    16
    Default Error VBA DimAligned
    I have problem with this VBA, anyone can Help???
    Sub DimAlignd()
        Dim ws As Variant
        Dim ACAD As AcadApplication
        On Error Resume Next
        Set ACAD = GetObject(, "AutoCAD.Application")
        On Error GoTo 0
        If ACAD Is Nothing Then
            Set ACAD = New AcadApplication
            ACAD.Visible = True
        End If
        ACAD.ActiveDocument.Utility.Prompt "Bla Bla Bla...!"
        Dim Coords(0 To 2) As Double
        Dim Coords2(0 To 2) As Double
        Dim ObjEnt As AcadDimAligned
        Dim n As Integer
        Dim LastRowXY As Integer
        Set ws = Worksheets("Coord_PENZ").Cells
        LastRowXY = ws(Rows.Count, 2).End(xlUp).Row
        Dim DimAligned As Variant
        For n = 2 To LastRowXY - 1
            Const Angl = 0.2
           Coords(0) = ws(n, 2)
           Coords(1) = ws(n, 3)
           Coords(2) = ws(n, 4)
           Coords2(0) = ws(n + 1, 2)
           Coords2(1) = ws(n + 1, 3)
           Coords2(2) = ws(n + 1, 4)
           Set ObjEnt = ACAD.ActiveDocument.ModelSpace
           .DimAligned Coords, Coords2, Angl
           ObjEnt.Update
         Next n
     End Sub
    Turlock, CA
    6,420
    Default Re: Error VBA DimAligned
    When asking for help with code please give more details. State what the problem is. What line of code is giving you a problem. What you expect to happen vs what actually is happening.
    C:> ED WORKING....
    LinkedIn
    2014-01
    16
    Thanks Ed Jobe,
    this my problem in ObjectEntity not work
    Set ObjEnt = ACAD.ActiveDocument.ModelSpace.DimAligned Coords, Coords2, Angl
    2014-01
    16
    this my file maybe anyone wanna try....
    2012-11
    Italy
    65
    you must use AddDimAligned method wich has the sintax "RetVal = object.AddDimAligned(ExtLine1Point, ExtLine2Point, TextPosition)", where all parameters are three-element array of doubles.
    so try this
    Option Explicit
    Sub DimAlignd()
    '    Dim ws As variant  '<---- I'd not use variant variable for what you already know it'll be a "Range" object
        Dim ws As range'<---- Use proper object type variable instead
        On Error GoTo 0
            ACAD.Visible = True
        End If
        Dim Coords3(0 To 2) As Double '<----------- add this
        Dim n As Integer
        Set ws = Worksheets("Coord_PENZ").Cells ' <------- warning: you must be sure to executethis routine while "Coord_PENZ" is the active worksheet
            Const Angl = 0.2
            Coords3(0) = (Coords2(0) + Coords(0)) / 2 '<----------- add this
            Coords3(1) = (Coords2(1) + Coords(1)) / 2 '<----------- add this
            Coords3(2) = (Coords2(2) + Coords(2)) / 2 '<----------- add this
            'Set ObjEnt = ACAD.ActiveDocument.ModelSpace '<----------- NO
            '.DimAligned Coords, Coords2, Angl           '<----------- NO this
            Set ObjEnt = ACAD.ActiveDocument.ModelSpace.AddDimAligned(Coords, Coords2, Coords3) '<----------- add this
            ObjEnt.TextRotation = Angl '<-----' I guess the Angl variable was to rotate dimension text
            ObjEnt.Update
         Next n
     End Sub
    also note what I thought about the use of your "Angl" variable
    bye
    2014-01
    16
    Thankyou very much RicVBA, its work now
    thank alot to admin ...
  1. Dimaligned LISP routine
    By CCarleton in forum AutoLISP
    Last Post: 2015-06-17, 05:45 PM
  2. Replies: 0
    Last Post: 2011-03-17, 06:54 PM
  3. Error closes Revit: An error has occurred while drawing the contents of this window.
    By chasen_forever in forum Revit Architecture - General
    Last Post: 2010-05-07, 03:38 PM
  4. Replies: 8
    Last Post: 2009-10-27, 12:03 PM
  5. Error when loading custom linetype - Error reading shape file
    By drafting.82475 in forum AutoCAD Customization
    Last Post: 2007-04-19, 07:36 AM
