Thread: Get a family in the drawing
    2014-01
    8
    Default Get a family in the drawing
    Hi -
    Using code, I'm trying to determine if a family with a particular name is in the Revit file, and if so, define a family variable for that family (ex. "Dim m_f as Family = ..." in Visual Basic).
    Any ideas?
    Thank you!
    2013-09
    Boston
    9
    Default Re: Get a family in the drawing
    Here's a macro that looks for a family named "Single-Flush" of the Doors category
    public void getFamily()
    Document doc = this.ActiveUIDocument.Document;
    string familyName = "Single-Flush";
    Family f = new FilteredElementCollector(doc)
    .OfClass(typeof(Family))
    .Cast<Family>()
    .FirstOrDefault(q => q.FamilyCategory.Name == "Doors" && q.Name == familyName);
    if (f == null)
    TaskDialog.Show("info", familyName + " does not exist");
    else
    TaskDialog.Show("info", familyName + " found");
    Hope this helps
    Regards
    Harry
    http://boostyourbim.wordpress.com/
    2014-01
    8
    Thanks!! You wouldn't know how to translate the following to VB.net would you? I've tried but can't seem to get it to work:
    .Cast<Family>()
    2013-09
    Boston
    9
    I don't. There are a bunch of free online c# to vb converters you can try.
    2007-07
    London, UK
    361
    Quote Originally Posted by Dr. Emergence View Post
    .Cast<Family>()
    That is kind of a duplicate.
    Both methods can be replaced by a single OfType<TResult>() method, also with deferred execution.
    Although not risky in this case, Cast can come with a Invalid Cast exception that never happens with the OfType Linq extension.
  1. Replies: 0
    Last Post: 2012-07-04, 08:07 PM
  2. Bind all Xrefs in a drawing, and perform the task on numerous drawing files
    By JeffThomasIII in forum AutoCAD Customization
    Last Post: 2007-06-19, 03:34 PM
  3. Replies: 2
    Last Post: 2007-05-17, 10:50 PM
  4. Replies: 2
    Last Post: 2006-05-10, 06:38 PM
  5. Replies: 2
    Last Post: 2006-05-02, 04:41 PM
