Wish List System
The FRAMES command controls Image, Xref, and PDF frames. But leaves out Wipeout frames. The TFRAMES command toggles Wipeout and Image frames. But leaves out Xref and PDF frames. I wish these commands would include all frame types.
Not sure what version you're using (2014 here), but it appears that the only *FRAME system variables that the FRAME (SETVAR) Command doesn't account for are OLEFRAME, and POINTCLOUDCLIPFRAME:
Command: SYSVARWATCH
SYSVARWATCH = ON
Command:
Command: FRAME
Enter new value for FRAME <3>: 2
[SysVarWatch] : System Var Changed : IMAGEFRAME = 2
[SysVarWatch] : System Var Changed : WIPEOUTFRAME = 2
[SysVarWatch] : System Var Changed : DGNFRAME = 2
[SysVarWatch] : System Var Changed : DWFFRAME = 2
[SysVarWatch] : System Var Changed : PDFFRAME = 2
[SysVarWatch] : System Var Changed : XCLIPFRAME = 2
[SysVarWatch] : System Var Changed : FRAME = 2
Note - Not all *FRAME system variables allow the same common 0-2 integer value, and obviously do not account for FRAME == 3.
