Thread: Civil 3d Fatal Error opening drawings
    2015-12
    Utah
    10
    Default Civil 3d Fatal Error opening drawings
    I keep getting this error "Fatal Error: Unhandled e0434352h Exception at fd0a940dh". It does this on every computer here at the office, but if I close AutoCAD all the way down and open the drawing through windows explorer, it opens just fine. I have ran audit and -pu. I cant run a recover because it will just crash on me. Once I get the drawing open through windows explorer I don't have any problems. This is not just one drawing. Its pretty much any drawing I try to open. Thanks in advance for your help!
    Civil Engineering Moderator MHultgren's Avatar
    Central Iowa
    1,444
    Default Re: Civil 3d Fatal Error opening drawings
    Is it just the one drawing? I would try inserting it into a blank drawing at coordinates of 1,1,1 then explode it and move everything back to 0,0,0 and save. Make sure all your layers are thawed and on.
    Active Member nelson's Avatar
    2015-11
    Portland, MI
    93
    I was going to say try cleaning up regapps using autodesk's tool for 2014 but I think I know your problem. By opening up from windows explorer you are using the default profile, not a custom profile.
    If your company is like most you have a custom profile that you put into the shortcut to launch into.
    Shortcut Properties, Target location ="C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\acad.exe" /ld "C:\Program Files\Autodesk\Autodesk AutoCAD Civil 3D 2014\AecBase.dbx" /p "C:\xxxxxxxxx\2014LocalSupport\Profiles\2014c3d.arg"
    There must be something wrong with your custom profile, whether it be a custom lisp, bad code, or something else. I'd start there and build a new one or remove the custom support paths you put in and add them back one at a time.
    Good luck
  1. Fatal Error opening Design Center (ADCENTER)
    By rwingender in forum AutoCAD Map 3D - General
    Last Post: 2012-01-19, 07:12 PM
  2. FATAL ERROR OPENING .DWG FILE
    By camille.211051 in forum AutoCAD General
    Last Post: 2009-03-16, 02:07 PM
  3. Fatal Error when attaching an image to my drawings
    By dortega4269 in forum AutoCAD General
    Last Post: 2006-11-16, 09:26 PM
  4. FATAL ERROR every time when Opening a certain drawing file
    By randyspear in forum AutoCAD General
    Last Post: 2006-05-08, 12:58 PM
