Thread: DXF files as Zip files
    2014-03
    2
    Question DXF files as Zip files
    On some of our systems, when a flat pattern is saved as a DXF file, it is created as a zip file. Where is the setting to change this? I seem to have found a file,
    C:\Users\Public\Documents\Autodesk\Inventor 2014\Design Data\DWG-DXF\exportdxf.ini , that contains a setting for USE TRANSMITTAL, but on my system it is set to Yes and I don't get zip files. how do we control this?
    Turlock, CA
    6,409
    Default Re: DXF files as Zip files
    I have no idea what a flat pattern is. On the pc's that create zip files, are they using ETRANSMIT? That creates zip files. Watch them do a save and take note of the exact steps they use to create the zip.
    C:> ED WORKING....
    LinkedIn
    2014-03
    2
    This is actually done through software, but it does the same manually. On a sheet metal file, right click on the flat pattern and use save as and set to the DXF type. There used(?) to be a setting for "USE TRANSMITTAL" to have a zip file created, but I cannot find it anymore.
  1. Replies: 0
    Last Post: 2012-12-10, 01:36 PM
  2. Newbie trying to understand central files vs. import revit files
    By smgdesignbuild in forum Revit - Student Support
    Last Post: 2009-05-05, 03:22 PM
  3. Replies: 2
    Last Post: 2007-06-12, 11:23 AM
  4. Replies: 4
    Last Post: 2007-05-23, 04:37 PM
  5. Can you convert/export Revit files into pdf or plot files?
    By petercronin97702 in forum Revit Architecture - General
    Last Post: 2005-12-09, 01:47 AM
Tags for this Thread
