Thread: A serious error has occurred-can't open the recovery file
    2014-03
    Default A serious error has occurred-can't open the recovery file
    while working i had a crash prompting a serious error has occurred that i should save my work in a new file before continuing and i did but i can't open the file and the recovery file cos it keeps prompting the same error.i tried using the audit box it didn't work.
    any suggestion on how to recover my project?
    2009-03
    Somerville, MA
    1,060
    Default Re: A serious error has occurred-can't open the recovery file
    Welcome to the forums! I'm sorry that your first post is to try to troubleshoot a fatal error.
    Does the project have any linked Revit files? We've encountered similar errors but the problem is actually in the linked file. You may be able to open the linked file(s), correct the problem, then try opening the main model again.
    If all else fails, you should contact Autodesk support (subscription.autodesk.com). They take this kind of problem very seriously and are usually quite prompt. They've been able to recover a few corrupt files for me over the years.
    2002-09
    Madison, WI
    5,687
    The other option would be to roll the project back and use the restore back-up. If you're saving every 20min or so that should be all you've lost. I would start as Damon has suggested above. If that fails next option is restore the back-up. If that fails, then Adesk may be your only hope.
  1. Replies: 13
    Last Post: 2010-07-09, 11:58 AM
  2. Fatal error + recovery file =/= crash?
    Last Post: 2010-06-04, 03:33 PM
  3. Fatal Error - can't open recovery file
    By Colin Blackford in forum Revit Architecture - General
    Last Post: 2009-12-08, 12:10 PM
  4. Replies: 2
    Last Post: 2006-05-10, 06:38 PM
  5. "An unknown error has occurred while accessing the central file"
    By mark_a in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2004-09-17, 01:11 PM
