I get the following error every time I open a new drawing:
"AutoCAD Message
No scale has been set. Please type SCL at the command prompt to set the scale."
At the same moment the error is up, the command line says:
"AutoCAD menu utilities loaded.netload Assembly file name: C:\Program Files\Microvellum\Toolbox 7\Microvellum.Toolbox.dll"
When I do type SCL at the command line, I can see the following in the command line:
-SCL
-Unknown dimension style.
-Dimension style is annotative.
-Program ERROR
-Resetting environment bad argument type: consp nil
There is an annotative dimension style, but, why it is "unknown" I do not know.
So, it will not stick or stay at whatever scale selected and I get the same AutoCAD Message again when opening the file.
My coworker says and internet research seems to be pointing at some aspect of the Microvellum install or settings that are not right.
Please help, thank you.
Q
