This is my first time ever on AUGI forum!
I have AutoCAD Architecture 2014 Student Version downloaded from Autodesk. I am trying to create different wall styles within a specific project. I'd like to have the 8X8X16 CMU walls be composed of the CMU wall AND a footing to go along with it. I'm thinking that if this is possible then the footings will "clean up" along with the walls and the walls will show up in section views with their footings. Can this be done, and if so, can you give the footings (stem width and height, pad width and height) dimensions? THANKS!
