Thread: Tag placement after rotating/moving section?
    2008-11
    12
    Default Tag placement after rotating/moving section?
    I've just had to rotate and relocate my project, after it had been tagged and dimmed in a whole load of views on sheets - plans and sections. Now, I'm used to tags disappearing off a large distance to the side on sections, and having to re-tag elements when this happens, but this time, when re-tagging, I can only seem to place the tags in the same place as the ones I've just had to erase, i.e. at a long distance from the member in question. Obviously, this is not very good! Does anyone know how I can get round this, apart from re-creating the sections or using dummy text instead of tags (these are the only solutions I've thought of so far)
    As always, thanks in advance for any help.
    2008-11
    Australia
    754
    Default Re: Tag placement after rotating/moving section?
    Try just turning the leader line back on (or off if its already on)
  1. 2016: Section Settings before placement
    By Ryan Cockerill in forum Revit Architecture - General
    Last Post: 2015-08-26, 07:26 PM
  2. 2013: Rotating the view without moving the model
    By Sharpy74 in forum Revit Architecture - General
    Last Post: 2013-02-28, 09:51 AM
  3. Suggestions for moving/rotating significant portions of a building?
    By FWSchreck in forum Revit Architecture - General
    Last Post: 2011-04-29, 05:17 PM
  4. Preview objects when rotating or moving
    Last Post: 2008-03-04, 03:46 PM
  5. moving placement of the plus sign in alignment labels
    By Maverick91 in forum AutoCAD Civil 3D - General
    Last Post: 2007-04-11, 06:50 PM
