Thread: Batch Plotting Issue
    2015-10
    215
    Default Batch Plotting Issue
    Issue 1:
    I don't know if this started when I upgraded to version 2014 or if it started when my hard drive was reformatted shortly after that. Anyway, here is my issue. When I go to publish a folder of files, the files to seem to get sent to the printer until AutoCAD is finished publishing. I think they are all queuing up on my local system and only getting released once the whole batch is done. This can be a substantial delay.
    Issue 2:
    I don't know if this is a bug or a system issue. From version 2012 to 2014, when I go to select the files I want to batch plot, it takes a while to actually select them. That's not so bad. The bigger problem is that if I select too many, AutoCAD just sits with the progress donut spinning. It basically freezes. Then I have to kill it, restart it, then publish in smaller subsets to achieve my goal.
    2015-10
    Colorado Springs, CO
    369
    Default Re: Batch Plotting Issue
    Publish has always worked in this way afaik... When sending a batch of prints, it releases them all at once.
    I would say your second issue is a machine issue, we also went from 2012 to 2014 and I can't say that I've noticed that.
    2009-11
    5,719
    1+
    I've historically had issue with publish as well, which is why I mostly rely on AUTOPUBLISH now to automagically spit out a PDF when I save my sheet drawings... I did end up having to tinker a bit to get AUTOPUBLISH to work properly (i.e., only produce PDFs for exhibits, and sheets, not model/XREFs, etc.).
    If you stick with PUBLISH, send smaller batches... If memory serves, I would only send 20-50 individual layouts at a time max.
    Cheers
    Computer Specs:
    Cairo - no, not Illinois
    5,069
    for issue 1, look at the PUBLISHCOLLATE setting.
    0 A published sheet set is processed one sheet at a time. Separate PLT files are created for each sheet. If the sheet set is published, the sheets might be interleaved with other plot jobs.
    1 A published sheet set is processed as a single job. A multi-sheet PLT file is created. If the sheet set is published, it is never interleaved with other plot jobs.
  1. need help batch plotting to PDF
    By oompa_l in forum AutoCAD Plotting
    Last Post: 2009-02-14, 02:37 AM
  2. Batch Plotting
    By rmartinez in forum AutoCAD General
    Last Post: 2008-01-17, 04:17 PM
  3. BATCH PLOTTING HELP
    By david_peterson in forum ACA General
    Last Post: 2005-05-26, 02:11 PM
  4. Batch Plotting
    By hydestone2002 in forum AutoCAD LT - General
    Last Post: 2005-02-23, 08:23 AM
  5. Batch Plotting in MDI
    By jnduratek in forum AutoCAD Map 3D - General
    Last Post: 2004-08-23, 01:02 PM
