Thread: Schedule Calculated Value Formula - Help!
    2016-01
    7
    Default Schedule Calculated Value Formula - Help!
    I'm attempting to create a (very long) formula for a circuit schedule, and I'm having issues getting the proper dictation for a simple formula before I start conjoining pieces to make the large one.
    Essentially what I'm desiring to do is to insert a label within the schedule that shows the office standard of branch circuit labels. For example, a HNG #12cu branch circuit is labeled A20 within our office, a HHNG #12cu branch circuit is labeled B20, etc. I'm attempting to have the formula look at the calculated text within the Wire Size column (that I will later hide) and then based on the exact information shown for each circuit, spit out a label that I've told for each combination of wire sizes (yes, that will make for a very large formula).
    Just to try and get one instance to work, I've tried the following formula:
    if(Wire Size = "2-#1, 1-#1, 1-#6", "B125", "False")
    (This is attempted under a Common discipline and Text type)
    This formula kicks back the error "Improper use of boolean expressions."
    Once I can master getting one wire size correctly dictated, I'll do something along these lines:
    if(Wire Size = [text 1], [label 1], if(Wire Size = [text 2], [label 2], if(Wire Size = [text 3], [label 3], if(..... ))))))etc.
    I'd appreciate any help with either this formula, or possibly even a better way to have a "smart" auto-completing column of custom labels for calculated wire sizes.
    2008-03
    55
    Default Re: Schedule Calculated Value Formula - Help!
    Hi rothfus7,
    You can't evaluate text values in schedules.
    Thanks,
  1. Calculated Value in Key Schedule
    By jon111712 in forum Revit Architecture - General
    Last Post: 2014-04-10, 01:10 AM
  2. 2013: Schedule - calculated value / calculated field
    By RayRay4105 in forum Revit - API
    Last Post: 2013-02-23, 04:30 PM
  3. Calculated Value in Schedule Problem
    By frustratedtonoend in forum Revit Architecture - General
    Last Post: 2010-02-19, 08:19 PM
  4. Schedule 'Calculated Value' Formula (Numbers & Text)
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2007-11-27, 10:16 PM
  5. Ability to use totals/subtotals from schedules as formula fields in calculated values
    Last Post: 2007-09-18, 01:27 AM
